Black Hole Xbmc beta 02
I´ve installed twitch and tested severall streams ... works flawless.
Can you tell me the name the stream to test ?
I will reply in a minute if you do the same!
What Mediaplayer do you use on XBMC?
Asks and answers in this section, please! ---> http://www.vuplus-community.net/board/threads/external-player-in-xbmc.21286/
Best regards
Hello nunigaia
it's on world of tanks (ENG || Braincage || Cruiser, Destroyers, Ya) on this now. stream is fine but video freeze
And on (Kateclick) kate russell) BBC technology programme Click
Vuplus Duo2
Sorry
Just seen link to post
i dont know if anybody can help with this. i can only play some things plus no sound. can some1 advice me what player to use and how to get the sound. bh 2.1.5 solo2. thank you.
What player do you have installed on your Stb, i.e., what player are you using?
thank you for your prompt reply. i am using the 1 that is installed. i have just been reading your 3 pages of mediaplayer 2 im not really bothered about subtitles, is that what the sub is for. basically which 1 should i use on my solo2 bh 2.1.5 thank you.
Actuallly i use Mediaplayer2 to play all media on my STB with SubsSupport, last version you can found here --> http://www.vuplus-community.net/board/threads/external-player-in-xbmc.21286/page-3#post-167425
Follow the guide, with this files ... it´s easy! --> Guide here --> http://www.vuplus-community.net/board/threads/how-to-install-mediaplayer2.22012/
thank you sir, yes i realized once i got reading. and all is ok. i have noticed that some channels have no sound is that down to addons or mp2. again thank you for your guide now its playing thanks to you.
Great ... I´m happy for that
thanks for you reply
thank you for your ecelent guide!
Is there any possibility to upgrade to Kodi Helix in BH 2.1.5?
Thanks
A good idea is the future of this project. :)
I can not watch TV or movies torrent. Rutor org plugin installed here
https://superrepo.org/get-started/
, with this plugin established Ace Stream Player. But at the opening of any film swears that Ace Stream can not play the video stream.
May need to adjust the ace Streit player to play p2p stream?
Since on Android and Windows version XBMC, Rutor org plugin works fine.
Can you solve this problem.
:thanks:
Staff do not know the correct topic , more whenever I use XBMC and then closing it always generate crasch_xbmc file in HDD . I looked and not acheio what is causing this crash . If they can see and say .
The image I am using is the BH2.1.5 SOLO2 .
With BH 2.1.4 MyTube player is working, after downloading and installing MyTube Player IPK packages plugin from Black Hole addons plugins. But Yahoo weather is not working. It shows error connection
yes I can confirm nbc sports extra working now I've got my piavpn working in solo2
and also istream is working as it should
How did you get nbcsports working? Every time I select the golf channel I only get a black screen. I have my vpn setup. Any suggestions? Is there an external player that you need to use?
I can only get NBC working on Pc and Android. I had to get an updated file for it to work but I put this ZIP file on the box, installed it and it didn't work. But it worked ok on the laptop and Nexus :-(
I tried KodiDirect and it worked. Hopefully we can get a fix for xbmc. I believe it's to do with the player as it works in Kodi but not Xbmc.
