Black Hole Xbmc beta 02
I have some questions!
The satellite part is handled by Enigma 2 or it is another software integrated with XMBC?
If it is the second option I imagine the satellite part to not be much developed (at least for now) for example the card readers work?
XMBC support the dynamic frame rate changing? I know in the Android NMT it cannot be done for firmware limitation DUO2+ has the same limitations? What about the audio passthrougt of the HD audio codecs (DTS True HD and so on)? Is this supported? It will be? H264 is decoded via hardware?
Loats of add-ons working on xbmc now . Just one think i hope going to get it to work next is the subtitles to work on xbmc. Tried to get settings changed but nothing comes on when trying to download subtitles from addons. Can you look at it bh team. Thank you
Best image..thanks for the good work BH Team..i hoop next version wil have subtitles on xbmc..
Member oblivian posted this and it works for subtitles:
telnet one line at a time
opkg install http://dl.bintray.com/mx3l/generic/enigma2-plugin-extensions-subssupport_1.5.0_20150304_all.ipk
opkg install http://dl.bintray.com/mx3l/generic/enigma2-plugin-extensions-mediaplayer2_0.57_20150204_all.ipk
opkg install http://dl.bintray.com/mx3l/generic/python-xmlrpc_2.7.2-r7.17_mips32el.ipk
REBOOT box
put this file
https://mega.co.nz/#!kNR3UQxa!ar2YnlLScIZ-uOKMfnFN3Huhdmq2U22xaCCKzvQgME8
in usr/lib/enigma2/python/Plugins/Extensions/XBMC
make safe backup of original file first
that's it
Cheers!
I forgot to say that to open subsupport you need do press the subtitles button on the remote.
I also had to uninstall subdownloader and mediaplayer1.
Cheers!
1. Handled by Enigma2
2. I don't know. Actually XBMC into Vu+ is under developmenet so specs and what is supported is not so clear.
Maybe I've intention to try this image but could someone respond to my questions of before?
Thanks!
Try directly BH 2.1.5 that is most updated comparted to this one.
update drivers
added many missed modules.
Many addons working now like:
Icefilm working
1Channel working
youtube working
Classic Cinema working
ecc...
Please test and report addons working / not working in xbmc section
hi there. i loaded this and now my vix duo freezes on startup? cant even get menu. can you help please. thank you
