BlackHole 3.1.0 Vu+ Duo2
Same thing with my duo2.When i install a plugin no matter which ,the duo2 don't load up,you have to switch it from the rear switch of the duo2.This issue don't happen on my vu+zero.
Yes same here and obh pli vix vti works fine and not bh so something is broke with bh and nothing is done
I saw about this image, which is better than previus, but i usually put the channels through the dreamset editor, where i can edit from my pc , all the channels i want, and then i send to my box vu+ duo2. Could you explain why now , the editor doesen't send like other previus images ? Maybe is another mode more confortable that i don't know, to edit with this image !!! I use 4 satellites and terrestial as well, and to edit all channels through remote control, is so hard. It's a something with etc/enigma2/ folder, for this reason i suppose it goes to crash.
