BlackHole VU+ Duo 1.3.6 - oe 1.6
I use this image in flash and use PHDP and VIX in multi-boot.Every thing is ok but one question:why isn't there DVD payer in menu?
You can add it... it is a little tricky however.
You need to go in Menu', Setup, Software Management and manage extension (hope it is in this location... I cannot check now).
You have to go to Multimedia and select DVD Player, then go to System and select Hotplug extensions.
Install them all... enjoy DVD Player :)
Thanks my friend i will check it. Also BA ve 5.4.41 work fine for me.
How You installed BA that work normal in BH 1.3.6 in flash ? Please explain step by step,because I tried with BA 5.1.41 and last 5.1.43, ipk files and can not install BA in flash, I received 2 errors.
Hello Dzoni. I used this section
http://www.vuplus-community.net/board/threads/a-tutorial-for-meoboot-using-barry-allen-that-work-smoothly-on-vu-duo-oe-1-6-images.365/#post-2984
and every thing is ok for me. i don't know what is happening for you.can you explain which parts you have problem.
This is for VTI 2.1 in flash, not BH 1.3.6 ! I tried same like written in that post but received on screen 2 errors:
1. Can not install BA
2. Couldn't find part enigma2 berry allen....
I know that is for vti in flash. I used that for Black hole.I downloaded BA Ve 5.1.41 in other from .maybe BA have problem in this from. try to install and download it from other from.
At the moment we are investigating about malfunctions of these kind of devices but we cannot estimate if we release the support of these devices. It's too early to give a precise date.
I hope you can understand my words :)
@angelofsky1980,
Thanks all team meambers for picking up this image again.
For your info, VolarBlack 850 works without problems with the drivers from DE BH 1.33c. Only slight audio sync problems with FTA channels, but can be solved with pushing the || key. The scrambled channels have sync problems for a few seconds only, but this isn't annoying, so adding the drivers shouldn't be a problem and very much needed, so we don't have to add the drivers manually each time we upgrade this fine image.
I have several DVB-T USB sticks, (Freecom DVB-T, Terratec cinergy dual tuner USB XS and Volarblack 850) so we can test other drivers if it is needed. Can understand however, that there are a lot of other issues which need the attention of the team.
@angelofsky1980,
I see already that there is a topic for this Avermedia stick in the Italian forum, so we will test the behaviour in OE1.6.
As I look in your drivers listed, is it correct to say that you use the next drivers:
xxxx-dvbt-nova-t-usb2_14592_del.tgz
xxx-dvbt-dib0700_14592_del.tgz
and according to earlier listings, the next USB DVB-T devices are suported by these drivers:
ASUS:ASUS U3000
ASUS:ASUS U3000H
ASUS:ASUS U3100
AVERMEDIA:AVERMEDIA EXPRESS
AVERMEDIA:AVERMEDIA VOLAR
AVERMEDIA:AVERMEDIA VOLAR 2
COMPRO:COMPRO VIDEOMATE U500
COMPRO:COMPRO VIDEOMATE U500 PC
DIBCOM STK7070P
D STK7070PD
DIBCOM STK7700D
DIBCOM STK7700P
DIBCOM STK7700P PC
DIBCOM STK7770P
DIBCOM STK807XP
DIBCOM STK807XPVR
DIBCOM STK8096GP
ELGATO:ELGATO EYETV DTT
ELGATO:ELGATO EYETV DTT Dlx
EVOLUTEPC:TVWAY PLUS
GIGABYTE:GIGABYTE U7000
GIGABYTE:GIGABYTE U8000
HAUPPAUGE:HAUPPAUGE MYTV T
HAUPPAUGE:HAUPPAUGE NOVA T 500
HAUPPAUGE:HAUPPAUGE NOVA T 500 2
HAUPPAUGE:HAUPPAUGE NOVA T 500 3
HAUPPAUGE:HAUPPAUGE NOVA TD STICK
HAUPPAUGE:HAUPPAUGE NOVA TD STICK 52009
HAUPPAUGE:HAUPPAUGE NOVA T STICK
HAUPPAUGE:HAUPPAUGE NOVA T STICK 2
HAUPPAUGE:HAUPPAUGE NOVA T STICK 3
HAUPPAUGE:HAUPPAUGE TIGER ATSC
HAUPPAUGE:HAUPPAUGE TIGER ATSC B210
LEADTEK:WINFAST DTV DONGLE H
LEADTEK:WINFAST DTV DONGLE STK7700P
LEADTEK:WINFAST DTV DONGLE STK7700P 2
PCTV:pINNACLE PCTV282E
PCTV:pINNACLE PCTV73ESE
PINNACLE:pINNACLE EXPRESSCARD 320CX
PINNACLE:pINNACLE PCTV2000E
PINNACLE:pINNACLE PCTV282E
PINNACLE:pINNACLE PCTV72E
PINNACLE:pINNACLE PCTV73A
PINNACLE:pINNACLE PCTV73E
PINNACLE:pINNACLE PCTV73ESE
PINNACLE:pINNACLE PCTV801E
PINNACLE:pINNACLE PCTV801E SE
PINNACLE:pINNACLE PCTV DUAL DIVERSITY DVB T
PINNACLE:pINNACLE PCTV DVB T FLASH
PIXELVIEW:pIXELVIEW SBTVD
SONY:SONY PLAYTV
TERRATEC:TERRATEC CINERGY DT XS DIVERSITY
TERRATEC:TERRATEC CINERGY DT XS DIVERSITY 2
TERRATEC:TERRATEC CINERGY HT EXPRESS
TERRATEC:TERRATEC CINERGY HT USB XE
TERRATEC:TERRATEC CINERGY T EXPRESS
TERRATEC:TERRATEC CINERGY T XXS
TERRATEC:TERRATEC CINERGY T XXS 2
TERRATEC:TERRATEC T3
TERRATEC:TERRATEC T5
ULTIMA ELECTRONIC:ARTEC T14BR
UNIWILL:UNIWILL STK7700P
YUAN:YUAN EC372S
YUAN:YUAN MC770
YUAN:YUAN PD378S
YUAN:YUAN STK7700D
YUAN:YUAN STK7700D 2
YUAN:YUAN STK7700PH
HAUPPAUGE:WINTV NOVA T USB2
@angelofsky1980,
The problem is the OE 1.6 migration.
The image 133F is OE 1.5. Also the kernel is little different from these two versions.
@angelofsky1980,
(removed long list)
I will publish a list of possible USB DVB-T devices divided by driver. Please be patient.
Thank you for your work for all team...it´s a great surprise this image as soon...the return of Black Hole...strongest ever...
greetings...
