BlackHole Vu+ Duo 1.4.1 Multiboot
I have just 2 plugin,de facto empty image.
See memory usage:
As far as I know the problem with the EPG is only indirectly related to total size of memory
The problem is the size EPG memory size and not the total size of memory which can be used.
Of course the EPG is not my specialty, but I think that's the problem.
Let us hope that our specialists for the EPG will find a solution for this problem.
For BitrateViewer plugin, you can get the version from OpenPLI which doesn't have any TPM protection. I installed it manually on BH 1.4.1 and works fine.
Hello
i have problem with EPG ( Nordic ) the box hang when i try to download epg, so i must turn of power on my box , i have a hdd and a usb , never had this problem before , with earlier release
Some FTA and encoded radio channels on Thor 1W dosn't work on vu+ duo! I need new audio codecs?
Same here, i confirm that radio channels on 1w don't work, mostly those from DigiTV provider.
The only way i can have sound on these channels is if i switch from a DVB-T service directly to one of the radio channels DVB-S. If i switch first to a DVB-S tv channel and after that to a radio channel, it doesn't work, i have no audio!
I have enabled positioner movement from customize but still it dont show. My conax card shows nans as time. Any help ?
Why this happing?
when I go to the channel list,,,,the highlited channel is not the one am watching,,,it jump up!
This was in old images,longtime ago, and not in BH 1.3.3D!
Is some thing , can do, to stop this,,,:rolleyes:!
Thanx
a911
