BlackHole Vu+ Duo 1.6.3 Hdmi Cec
I do not know for example in my playstation 3, but the menu does not work black_hole
my samsung tv is c7000 led 3D,and I have 4 options enabled
My friend,
Hdmi Cec is only experimental function. It may works or not depending from your tv compatibility. Tests only with 1-4 options which works and which does not.
Rgd MX
To understand the CEC last years was one big mess
CEC as a protocol is used by companies in different ways
not as a standard protocol with standard codes.​
My friend,
Rgd MX
To understand the CEC last years was one big mess​
CEC as a protocol is used by companies in different ways​
OK Matrix10, only the 3 option works,
Please create list of supported tv models in one post
It's very difficult to make a list of working devices because any TV producer use it's personal set of CEC commands and older TV sets should doesen't work correctly :(
Only try personally (and report here) the tests can build suitable and useful list :)
I have a Sony Bravia KDL46EX713 full 1080p TV.
The TV can see the Duo as Tuner1 (Black Hole).
Options 1 and 3 work, i.e. the Duo remote can put both boxes into Standby, and so can the TV remote.
Options 2 and 4 (the wake-up options) don't seem to work.
Hope that's helpful and thanks for the work so far on this :thumbup:
can't play any dts audio from my collection any help please
I put my USB key that contains a DTS audio but I can find nothing in it
i have mounted my stick correctly
I have audio dts like 13. Tranquility «Vastness».dts Vu+ duo didn't detect any file
musique\Blu Еlements Project - Forsenses DTS 5.1 [2009]\13. Tranquility «Vastness».dts
Format : Wave
File size : 47.0 MiB
Duration : 4mn 39s
Overall bit rate : 1 411.2 Kbps
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : LE / 14
Codec ID : 1
Codec ID/Hint : Microsoft
Duration : 4mn 39s
Bit rate mode : Constant
Bit rate : 1 411.2 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 44.1 KHz
Resolution : 24 bits
Stream size : 47.0 MiB (100%)
Format : Wave
Duration : 4mn 39s
Audio
Format : DTS
Codec ID : 1
Duration : 4mn 39s
Thanks for your output.
I will retreive a file like your and make some tests.
It's the first time I read for DTS audio files.
First: thanks for your work
But I can't play none .mkv - dts movies from my collection. They are copied in internal 320 G byte HDD. My movie player PCH-A110 can plays this films without any problems. What I make wrong?
Very strange.
Please post some details for your MKV files and where are located.
