BlackHole Vu+ Duo 1.6.5
thanks, great team
what about the HDD 3Tera, are any solution inside BH 165 angelofsky1980?
I haven't investigated around your issues and segnalations :(
hy, this is a great work;
but I wonder why dont you re-edit a image so that it looks like freebox revolution one
like this for ex:
this is the channel selection menu:
and this is the infobar :
can't vu+ support like these graphics??
Post this kind of requests into "Sking & Bootlogos" sections :)
like this for ex:
Maybe our skinner will like to do something like this, but personally i don't like to much something like this.
I prefer as it is now.
This image wont work with my new vu+ remote control with the hdmi button on, so back to image 1.64 where it was working
i had to buy new remote because the ok button was nok working so good with the old white remote control.
old white remote control working ok with image 1.65
new black remote with hdmi button not working with image 1.65 no problems with 1.64
W
So at it seems my remote belongs to a vu uno is there gonna be a fix or driver so i can use my new remote ?
Greath image BH team!!!!!!!!!!
As always!!!!!!!!
And new Beyonce Skin is very nice, it's good to switch from time to time!!!
W
I would speak to the seller of the remote and ask for the correct one for your box.
It is not an image or driver issue that you have been miss-sold.
yes i do.
but problem not resolved
old image not problem but this image have a problem.
Ok, Take the satellite.xml from the old image and try in the new.
As the problem only happens on one channel then it is unlikely to be an image problem.
Also you changed xml, scanned and replied in less than 4 minutes ?
yes ido!
no i am tring this Proposals before!
Therefore aswered quickly!
anyway :thanks:
I tested the Turksat
and I have no problems on that satellite.
Im using SAT settings/list from @Likra ,I have upload in a box with DreamBoxEdit
