BlackHole Vu+ Duo 1.6.7 kernel 3.1.1 beta2
this problem continues, the new beta version detects my wifi stick(dlink DWA-140 N) with the driver rt 2800 when the good one is rt5370 sta...
thanksss...
this problem is being revised? with an affirmative answer is enough.
could i change the wifi driver in root to solve detect wifi model ok??if you say me where are location files exactly i have to change i do it.
Thank you.
hello everybody
my wlan does not work, initially never had a problem like, this is a key named sagem!
for my external hard drive western digital 3b, it correctly detected this time, but it shows nothing inside, while there are several files and movies bm750 login: root
root@bm750:~# fdisk -l
Note: sector size is 4096 (not 512)
Disk /dev/sda: 3000.5 GB, 3000558944256 bytes
255 heads, 63 sectors/track, 45599 cylinders
Units = cylinders of 16065 * 4096 = 65802240 bytes
Device Boot Start End Blocks Id System
/dev/sda1 1 45599 2930190716 7 HPFS/NTFS
Hi , i was reinstalled VTI 3.1, connected my external hdd 3T and executed fdisk -1
here is the test performed with the image VTI 3.2, the HDD works correctly
* VTI Image *
welcome on your Vu+ ! - Kernel 2.6.18-7.3 (#1 SMP Tue Aug 23 00:01:55 CEST 20
bm750 login: root
hello everybody
dear ANGELOFSKY 1980
my wlan does not work, initially never had a problem like, this is a WLAN sagem model XG-760N!
for my external hard drive western digital 3b, it correctly detected this time, but it shows nothing in it, while there are several files and movies...
bm750 login: root
root@bm750:~#
fdisk -l
Note:
255
•here is the test performed with the image VTI 3.1, the HDD works correctly
* VTI Image *
bm750 login:
root
root@bm750:~#
fdisk -l
Note:
255
hello everybody
bm750 login: root
•here is the test performed with the image VTI 3.1, the HDD works correctly​
* VTI Image *​
welcome on your Vu+ ! - Kernel 2.6.18-7.3 (#1 SMP Tue Aug 23 00:01:55 CEST 20​
bm750 login: root​
root@bm750:~# fdisk -l​
Note: sector size is 4096 (not 512)​
Disk /dev/sda: 3000.5 GB, 3000558944256 bytes​
255 heads, 63 sectors/track, 45599 cylinders​
Units = cylinders of 16065 * 4096 = 65802240 bytes​
Device Boot Start End Blocks Id System​
/dev/sda1 1 45599 2930190716 7 HPFS/NTFS​
About your wifi stick I will look into web a solution (it's a zd1211 device).
About your hard disk, you should mount correctly it on BH with this telnet command:
ntfs-3g /dev/sda1 /mnt/hdd
for info
On the server you can find Elegance HD P2 skin
based on default BH 1.6.7 skin
but with a different OSD / movie players
you can try if you like
skin has the same speed and performance as the default skin.
Rgd MX
Hi mates.
I have the same problem. un fortunately, this image does not recognize my 2T seagate SATA internal HDD. HDD cannot be set in menu because of the mentioned cause. of course it does not have any problem with pendrives
dear angelofsky1980
the execution of: ntfs-3g / dev/sda1 / mnt / hdd
fix the problem and the hard drive is working correctly, but if the hard drive disconected or vu+ duo reboots, the disk is no longer recognized, and it comes back to the starting problem! is a solution for this
thanks four you
dear angelofsky1980
thanks four you
Edit file /etc/fstab
be sure that the line
/dev/sda1    /media/hdd  auto   defaults          0       0
is commenetd with # or delete it-
Add the line:
/dev/sda1  /media/hdd  ntfs-3g   defaults          0       0
thank you Shiro, but I don't understand! you can explain more step by step? thank you
Edit fstab file in /etc and replace line
with line
and reboot/ test
Or like this
rootfs / auto defaults 1 1
proc /proc proc defaults 0 0
devpts /dev/pts devpts mode=0620,gid=5 0 0
usbdevfs /proc/bus/usb usbfs defaults 0 0
/dev/mtdblock2 /boot jffs2 ro 0 0
tmpfs /var tmpfs defaults 0 0
tmpfs /tmp tmpfs defaults 0 0
tmpfs /dev/shm tmpfs mode=0777 0 0
#/dev/sda1 /media/hdd auto defaults 0 0
Look in your fstab file And you will know.
