BlackHole Vu+ Duo v. 1.4.3-B Multiboot
Hi,
Just for report this :
With this lastest realse, if I switch off my VU+ DUO HD by the rear power switch, I must initialise again the HDD
What do you think about this.
Regards
Hi,
Regards
I've tested what U'r claiming , on both BH images(on flash&Mboot),,found HDD initialized and mapped correctly,,,No issue with BH images, all are OK!
In one of your post , U said that your are using a backup image,,,,check it,,,and use the correct ones!
Gdluck!
Ok, Thanks for reply.
I will install new fresh latest BH version and see what happend.
Regards
Thanks for great image.
I find one bug, NFS server auto start don't work
Regards
I can confirm that Nfs server does not start automatically after reboot.
Is there a good media player plugin that works properly with this.. All media buttons working and videos playing correctly.
Yes, tried that one,, not a real easy one to use... There was one I downloaded but the pause and stop buttons dont work properly...
Other question, did you try press R botton on your RC?
Where are the files you want to play?
I am trying to play the files that are on my PC..... All recordings that are on my VU hard disk work fine,,
I have BH image working great, usb\t tuner, permanent time shift. I have a Samsung plasma that is networked to my pc files and they all work flawlessly on the Samsung. I have a projector that uses component. So I have to use the VU component out to projector and the VU HDMI out to the Samsung.
Is your pc hdd mounted on your box.
You maybe should try to use mount wizard to mount the location where files are on your PC, then try to play them.
It is mounted...They just dont play properly... I can select any movie or song or photo off my PC.. But they either freeze or do not respond to buttons, very erratic player..
Is there a problem with autocam settings? It was working here before, but not anymore.
I turn power off every night, maybe that have caused problems. I can see my autocam setting is still there in autocam meny.
But it will not start automaticly when i change channel.
Just want to say, autocam is working fine.
Couple days ago i changed the satellites.xml, so autocam had my old satellites.xml info.
