BlackHole Vu+ Duo v. 1.4.3-B Multiboot
thank you for the update
My friend ask me why you use in the name of this image "BlackHole Vu+ Duo v. 1.4.3-B Multiboot"
And on the warning we that:
WARNING BECAUSE OF NEW DRIVERS THIS IMAGE CANNOT BE INSTALLED IN MULTIBOOT. THIS IMAGE HAVE TO BE INSTALLED IN FLASH
Can i have more explanation about that!
Thanks
Thanks
Because you can find meoboot in this img to install others in multiboot.
BH In Flash, pure and clean as downloaded it!
BH In Mboot, using meoboot!(95%)
Other images, In Mboot, using meoboot,, for testing!(5%)
This how I understand it,,,since I"ve got My Boxes...and Starting from BH 0.12,,,,the most user friendly Image and stable !
:thanks:BH Team!
a911
I'm using 1.4.2.b now for a few weeks and the stability is ok only the dvdplayer gives a lot of crashlogs if you use it verry frequently.
Going to try the 1.4.3.b on the Vu+Duo.
Keep up the G00D work Team
"BlackHole"!
PiP shows the developers of images puts an effort in making this box functioning like my DMM-models. I don't care if it's not working at the moment, but I want you to know that I appreciate the work you guys put in to please us no good, unthankful, always complaining SoB's :)
dont work the avertv volar hd A835, why? dont work the driver of addons... "sorry, device not found"
Regard
Regard
Works.
For support ... post in the correct forum section and report the result of this command:
usbtuner -V
On the server I've released the 0.2.9 version who correct a big bug.
