this is reboot and first startup
BCM73250010
012
K1
K2
K3
K4
K5
Shmoo Version=3.6
DDR Freq=0x0000018E
%00000001%
RC1=00000006
WC1=FFFFFFF2
RC2=00000018
WC2=00000041
RC3=0000000F
WC3=FFFFFFF3
RC4=0000000F
WC4=00000041
NWC=0000001A
RC5=00000006
WC5=0000001A
RC6=00000018
WC6=0000001A
NRC=0000000F
RW=00000013
WW=0000004F
G=00000000 R=0000000F W=0000001A
BL=00000000
RC1=00000006
RC2=0000001F
BL=00000001
RC1=00000005
RC2=0000001F
BL=00000002
RC1=00000004
RC2=0000001B
BL=00000003
RC1=00000001
RC2=00000018
3
COPY CODE
AS567
CP16=80040483,BEA3519F,80000167
BCM97325B0 CFE v2.27, CFE core v2.12, Endian Mode: Little
Build Date: Wed May 18 10:18:50 2011 (shcheong@ncsh)
Copyright (C) Broadcom Corporation.
DDR Freq: 398MHz
CPU speed: 333MHz
Memory Config: 32-bit UMA
Device Tech: 1Gb
Total memory: 256MB
Total flash: 128MB
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Hub
CFE initialized.
checking usb
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:rootfstype=jffs2 root=/de
v/mtdblock0 rw mem=0x8000000
Loading: 0x80001000/6641640 0x806567e8/117352 Entry address is 0x804e96c0
Starting program at 0x804e96c0
Linux version 3.1.1 (amedeo@localhost.localdomain) (gcc version 4.4.3 (GCC) ) #1
Sat Dec 31 12:05:16 CET 2011
Fetching vars from bootloader... found 7 vars.
Early serial console at MMIO32 0x10400b00 (options '115200n8')
bootconsole [uart0] enabled
Options: sata=0 enet=1 emac_1=0 no_mdio=0 docsis=0 pci=1 smp=0 moca=0 usb=1
Using 256 MB RAM (from straps)
bootconsole [early0] enabled
CPU revision is: 0101954c (Brcm4380)
FPU revision is: 01739300
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
bmem: adding 144 MB RESERVED region at 112 MB (0x09000000@0x07000000)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0x00000000 -> 0x00010000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000000 -> 0x00010000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: bmem=144M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw ro
otflags=sync
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
MIPS secondary cache 128kB, 8-way, linesize 128 bytes.
Writing ErrCtl register=00800000
Readback ErrCtl register=00800000
L2 cache parity protection enabled
Memory: 105788k/262144k available (5068k kernel code, 156356k reserved, 1196k da
ta, 220k init, 0k highmem)
NR_IRQS:128
Detected MIPS clock frequency: 332 MHz (166.498 MHz counter)
Calibrating delay loop... 220.16 BogoMIPS (lpj=110080)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
NET: Registered protocol family 16
PCI2.3->SDRAM window: 512 MB
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource upg
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NTFS driver 2.1.30 [Flags: R/W].
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 206
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
loop: module loaded
Broadcom STB NAND controller (BrcmNand Controller)
bcmemac: Broadcom STB 10/100 EMAC driver v3.0
bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:1d:ec:00:05:da)
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
brcm-pm: enabling usb clocks
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 63, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 64, io mem 0x10480400
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 59, io mem 0x10480600
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
lirc_dev: IR Remote Control driver registered, major 254
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR LIRC bridge handler initialized
Linux video capture interface: v2.00
Success! Registering the characther device success with 0
blackhole initialised
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
No soundcards found.
TCP cubic registered
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
lib80211: common routines for IEEE802.11 drivers
EBI CS0: setting up NAND flash (primary)
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000001
B4: NandSelect=40000101, nandConfig=55042200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf18015
After: NandSelect=40000101, nandConfig=55042200
Block size=00020000, erase shift=17
NAND Config: Reg=55042200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
Found NAND on CS0: ACC=d3000000, cfg=55042200, flashId=ecf18015, tim1=4232222d,
tim2=00000d94
BrcmNAND version = 0x0200 128MB @00000000
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 2.0 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan: mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Creating 7 MTD partitions on "brcmnand.0":
0x000000000000-0x000007400000 : "rootfs"
0x000007400000-0x000007800000 : "kernel"
0x000007800000-0x000007c00000 : "boot"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 0
UBI: volume 0 ("rootfs") re-sized from 474 to 915 LEBs
UBI: attached mtd0 to ubi0
UBI: MTD device name: "rootfs"
UBI: MTD device size: 116 MiB
UBI: number of good PEBs: 928
UBI: number of bad PEBs: 0
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 928
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 1/0
UBI: image sequence number: 1479911056
UBIFS: parse sync
UBI: background thread "ubi_bgt0d" started, PID 36
UBIFS: start fixing up free space
UBIFS: free space fixup complete
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 114786304 bytes (112096 KiB, 109 MiB, 904 LEBs)
UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:12.
Freeing unused kernel memory: 220k freed
mount: mounting sysfs on /sys failed: Device or resource busy
procmk_init
dvb_bcm7325: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (vusolo)
bcm7335: hotplug_callback():
Hotplug - status.connected 0
CPU 0 Unable to handle kernel paging request at virtual address c07e53a8, epc ==
c07e53a8, ra == c073e4f4
Oops[#1]:
Cpu 0
$ 0 : 00000000 00000000 8556a200 c07e53a8
$ 4 : 85564800 00000000 00000001 001a0340
$ 8 : 11008400 1000001f 81200000 00000000
$12 : 00000000 00000000 0000000f 8061de30
$16 : 86f3cc80 00103000 86f30200 8642b800
$20 : 00000000 00000000 c073c7c8 00000001
$24 : 8061de10 00000000
$28 : 86ff2000 86ff3c00 ffffffff c073e4f4
Hi : 00000002
Lo : 39ce73d9
epc : c07e53a8 0xc07e53a8
Tainted: P
ra : c073e4f4 0xc073e4f4
Status: 11008003 KERNEL EXL IE
Cause : 10800008
BadVA : c07e53a8
PrId : 0101954c (Brcm4380)
Modules linked in: procmk
Process modprobe (pid: 54, threadinfo=86ff2000, task=86fee998, tls=77574490)
Stack : c0701e18 c0701dfc 00000001 00000001 00000041 c073ddf0 c073d280 8556a200
00000000 c0b03974 0000000d 00000020 00000001 86ff3c58 c0b038b0 00001000
80061f90 c0709abc 00000000 00000101 00000001 0000000c 00001000 00000000
00000000 00000000 00000001 0000000c 00000060 805f4460 805f20b0 80660000
fffffffe 00010000 805ee700 00000000 805f1f14 806630c4 8057148c 8002d4e8
Call Trace:
[<80061f90>] enable_irq+0x0/0x8c
[<8002d4e8>] tasklet_hi_action+0x14c/0x154
[<8002db28>] __do_softirq+0xbc/0x164
[<80063830>] handle_level_irq+0x98/0x118
[<8002dd78>] do_softirq+0x68/0x70
[<8001e304>] __wake_up+0x28/0x48
[<800022b8>] plat_irq_dispatch+0x118/0x1e0
[<8005c834>] module_sect_show+0x0/0x18
[<80003f6c>] ret_from_irq+0x0/0x4
[<8006f31c>] free_hot_cold_page+0x6c/0x2f0
[<8006cf74>] get_pageblock_flags_group+0x94/0xb8
[<80094db0>] __vunmap+0x78/0x11c
[<8004b218>] blocking_notifier_call_chain+0x14/0x20
[<8005e2d0>] sys_init_module+0x250/0x13f4
[<8000c5c4>] stack_done+0x20/0x40
[<8027e638>] __bzero+0xbc/0x164
Code: (Bad address in epc)
---[ end trace 9ecb101486205096 ]---
Kernel panic - not syncing: Fatal exception in interrupt
Rebooting in 180 seconds..
) and all works correctly.
