BlackHole Vu+ Uno 1.6.7 kernel 3.1.1 beta2
Hello,
I solved the hard disk problem (lost or freezes in picture after using several times the skip forward function) by mounting the hard disk into an external powered box (like Icybox) and connecting it with the e-sata cable to the UNO.
Now it works perfectly and I can use the skip forward or backward as many times I want with no freeze at all. :ice:
I'm very happy to read you have solved your problem ;)
BUT thats NO SOLUTION THE BOX should be able work with the HD itself
I agree, but as always when new kernel comes, new bugs are introduced and we must give some time to vuplus to fix the problems.....
For me, UNO would be a great box if vuplus can fix a better SATA handling and be able to flush the buffers at least when exiting an application in order to have a maximum free memory.
Has anyone had any issues with viewing on a iPad, I use Dreambox Live, all the free channels work fine. But the other channels just show a blank screen, I've set my settings to Multitunner, so it should be able to show the channels, this worked fine when I was on 1.6.6. I've even installed 1.6.7 beta 3. Still same issue.
