BlackHole Vu+ Uno 1.6.7 kernel 3.1.1 beta2
I installed Black hole 1.6.7, I will try Vix 2.3,when I restart theVU+UNO to flash the receiver (USB stick attached) this message appears instead of flashing,
No displayable files on this medium found ,should I put only the files on the usb stick? i.e without the folde >VUplus >UNO. I mean only the files in duo subfolder.
If you have others usb devices connected to the UNO, remove them before to install the new image.
For me this is not happening
but ,I have test with a newer version of the image.
With my skin, default image skin no symbols in Standby .
I have a dolby symbol only on the channel with Dolby
and only if i have selected dolby in the Audio menu in normal mode (not standby).
Wait for a newer image version maybe it is fixed.
Thanks friend but I can resolve the problem a new update of the FPGA, they must have fixed something in the FPGA because it had updated before placing image BlackHole Vu + UNO 1.6.7...thanks friend
I do not know what's changed
But last night I tested the more recent image, and I did not noticed the problem that you described.
Rgd to my Portuguese friends
MX
new image 1.6.7.& fınal 1.6.8 final new years
Can the beta version be updated with ipkg into a final release?
I was thinking to install the beta2 but as the final version seems very close I am in a waiting stage but if there is an upgrade path then I shouldn't wait ;-)
Where do you got the info about the final version release dates?
Update online is not supported by BH.
It seems to me that even with me WebBrowser not working
hopefully it will be in the next version fix ,
or is something wrong at the VU server at the moment.
FTP/USR/LIB/ENIGMA2/PYTHN/PLUGINGS/EXTENTIONS you delate webbroser and you from your (PC) you send VTI 0.4 webbroser to replace it then it's work fine. For webbroser VTI 0.4 ,you istall this image then;FTP/USR/LIB/ENIGMA2/PYTHN/PLUGINGS/EXTENTIONS /webbroser and you send it to your (PC) .
SORRY ,VTI 4.0 NOT 0.4 VERY SORRY
waiting to solve the problem on the cardreader VuSolo, I updated the VuUno, everything was perfect, congratulations, I just do not recognize the hard disk, I also updated the drivers
Hello and Merry Christmas to all
I just got a UNO under the Christmas tree :ice:
I flashed of course with latest Black Hole. All is fine, I have just a problem with EPG:
Is MediaHighWay EPG implemented ?
When I choose "GUIDE TV" channel on CSAT, I have a popup telling datas have been found, but when I press the EPG button, I have only the current program and the next one.
If I choose multi EPG it is only the graphic which is displayed, and only very few programs are displayed.
My question : Is there a way to get all the programs for a single channel in LIST mode (not graphic) apart from internet ? (works on my DM8000 with ICVS)
Thanks for your help.
It seems that the French MHW does not work
I do not know why.
Does not work with an embedded MHW nor with those of CrossEPG
I talking about the Satellite MHW epg not one from internet server.
Perhaps the problem with the French SAT provider.
when you see an image like PLI it has a option set as startup channel. This options comes when see your channel list and press menu
It is possible to
I have not tested PLI
But each image have something that the other image not have.
You have to choose one that you like.
We build the image with the options that we think should
be in the image, especially taking into account the performance and stability.
It is possible to
True. I am using Blackhole .
