BlackHole Vu+ Uno 1.6.7 kernel 3.1.1 beta2
Thanks for this new image.
Zapping fast, works fine on TV.
But in playing video on mkv it is no perfect. Sometimes movies freeze or sound problems.
After reading a movie, the memory is not cleaned. I use a script "Free Ram" to do that.(70 % memory more after that)
When I trying to download the Image Back hole 1.6.7 this message appears:
the file can damage your computer ( widows 7),should I download? its only site to download from.
Great forum/support
Thank you very much,I have download from this board,no message to damage the computer.
Regards
hello i have a vuplus uno and i have a problem with webbrowser in this new image bh 1.6.7 : I can't use cursor ,then i can't use this pluging thinks
You should check your Firewal/Antivirus first mate,all files here are 110% safe.Many Antivirus systems sends(wrong message??)-detect wrong malicious files.
i think webbroser and all the old plugings don't work well because this image bh 1.6.7 has a new kernel ?????????
Hi mates,
I tried to restore a backup file from BH 1.7.7 beta1 to 1.7.7 beta2.
It was successful but it did not restore installed plugins.
Is it normal for backup system?
Thanks for all your efforts
Hi mates,
No, it's not normal.
Maybe something didn't work fine during the backup.
@BH Personal Bk-up, when you want to restore settings,,,,,!
U have a choice to say YES or NO for plug-in (& other settings) to be restored!
However, some plug-ins need to be re installed!
thanks guys
i have uno and i put 1.6.7 beta 1 when i make serch to sat he didnt see any channel and when i put anther reciver he work i that from soft or i must put beta 2 and i make update for fpga
i think that all those problems because the new kernel and the definitive image 1.6.7 must have the new plugings for this new kernek.
Hi mates,
Can you tell us wich plugins didn't restore?
Hello guys, I use this new release since 3 days without any kind of issue. It's just fantastic !
Fast channel switches, and so on.
This post just to tell to the whole BH team a big THANK YOU !!!
thanks guys
read the last post on the first page
I have never seen any option like this, please explain more.
thanks
I want to install black hole 1.6.7 on my receiver VU+UNO (original FW) my question is,tried to update the FPGA firtst,but I dont see the FPGA folder in the list (upgrade FPGA) ...memory stick conected.I see only var,temp,boot etc....
should I install 1.6.7 first and then FPGA,
You have to update fpga with plugin in green panel then you can install new BH 167.
