BlackHole Vu+ Uno 1.6.7 kernel 3.1.1 beta2
I dont see the green panel mate,as I mentioned its a New VU+ uno (original firmware)
Menu>plugins>I see 3 options here 1-Picture player 2-media scanner 3-FPGA upgrade,when I press FPGA upgrade I see.etc,var,boot .lib etc... I dont see the the content (ST_ pro) of attached USB stick.
Look into /autofs folder ... I haven't here a box to verify the correct and full path :(
autofs folder
It stands >parent diroctery
Do I have to restart the receiver (after attaching the USB stick) from the main switch"back" or the receivers remote switch?
Everything is written on the front ( 1 ) page , last post
Thanks.
WebBrowser (Pay attention WebBrowser uses a lot of flash)
If you do not need do not install .
installation :
Menu > Setup> Software Managment >Manage Extensions > Network > WebBrowser>OK button>RED button>RED button>Green button
thinks my problem is not how to install this pluging,but it's not work ,it's stil blocked at the start up internet page ,and that urged me to restart my vuplus uno. THINKS
installation :
Friends with this new image is in the active LED symbol always dolby sound, no way to remove it I have taken many turns and can not find a way .... thanks
Do not post pictures because I have no camera ... thanks
LCD display dolby symbol ??
So it is normal if it is present Dolby.
You can not remove,but if you change audio with audio button you can remove.
try it and especially in channels that have no dolby sound is so strange that even in the sample stan by this symbol .. thanks friend
with the previous version beta 1 did not happen this
for me that is strange to see the Dolby symbol being on standby
For me this is not happening
but ,I have test with a newer version of the image.
With my skin, default image skin no symbols in Standby .
I have a dolby symbol only on the channel with Dolby
and only if i have selected dolby in the Audio menu in normal mode (not standby).
Wait for a newer image version maybe it is fixed.
It seems to me that even with me WebBrowser not working
hopefully it will be in the next version fix ,
or is something wrong at the VU server at the moment.
THINKS the webbroser work very well in VTI 4.0 with newkernel 3.1.1 but i prefer blackhole images and i wait for next version
I installed Black hole 1.6.7, I will try Vix 2.3,when I restart theVU+UNO to flash the receiver (USB stick attached) this message appears instead of flashing,
No displayable files on this medium found ,should I put only the files on the usb stick? i.e without the folde >VUplus >UNO. I mean only the files in duo subfolder.
