BlackHole VuDuo2 2.1.7
i mean can install the backup in the hdd by open meoboot?
Take a look to posts from @@Matrix10 on shoutbox, cause there are some fixes to this image!
did you mean skin issue or other fixes?
thank you
can install the backup in the hdd by open meoboot? >> NO
did you mean skin issue or other fixes? >> Skin Harddrive panel fix
Excellent job - did a fresh install rather than using personal back up so well and truly up to date!
thank you Matrix10
tell me the steps to find Skin Harddrive panel fix
another issue: the box restart and crash every time i opened mytube.and i the blue button of vertual keyboard does not reply.
thanks again
Thank you for image.
I want to know which list of the images should be in multiboot thus is too easy to say blackhole2.1.7 openboot meoboot and the first image in multiboo should not be remains locked.
The guide usb formatting before on older images was all in italian language now no
thank you Matrix10
thanks again
skin BUG FIX you can find
green button >>yellow button >>Addons Downloads Manager >>Black Hole Image Skins >> Skin DEFAULT BH 2.1.7 (BUG FIX HDD Initialisation)
MyTube working without crash if you using default skin and you have not change image (test with clean image)
MyTube you have to download from
green button >>yellow button >>Addons Downloads Manager >>Black Hole Addons Plugins >> MyTube Player (IPK Packages) (Black Hole E2)
For search you have to use Blue button for Virtual Keyboard.
A bit of a novice question, but how can you add the extra line to the channel description that adds the resolution, the name of the sat etc. ? Can this be configured?
And by the way the nicest skin since I moved to Blackhole from VTI!! Many thanks for the great work.
I installed black hole 2.1.7 to vu+duo2, when I select standby power off mode, it shuts down completely. With the previous 2.1.6 version everything was fine, with standby power off mode selected, device goes to standby ant displays a clock on the lcd screen.
thank you
Skin fixes, of course!
As @Matrix10 fixed this 3 three skins regarding Blackhole 2.1.7 image ( issue problem on skins dued harddisk initializaion error ).
After the installation of a clean image ??
NO Backups,no plugins,no multiboot ??
Yes just fresh image, I scan MyHD package from badrsat 26east vu+Dou2 configures common interface and after 1 of watching channel box restarts.
I also can't stream channels over LAN to my smart TV in BH214 I used to have dou TV & Radio list via Dlna from which I could stream channels on my home network.
I could do similar setup via mediatomb with a huge effects and creating Playlist my self but can't stream eutelsat 4k channel on my 4k TV. For that I'm forced to use smart IPTV app on LG TV and I don't enjoy that.
Are you talking about BH 2.1.4 or BH 2.1.7
In my BH 2.1.7
I do not have the same box setup/config and Im not using the same
so I can not say for all problems that you have.
But my box does not have a single crash.
Streaming and transcoding streaming works without problems.
I've made a list in the Tuner server panel.
I have test with mediaplayer on my PCs with and witout transcoding both working .
So I can not help you because I can not test the same setup you have.
Is the same in BH 2.1.7
If you select Standby .
If not so then you've done something.
We have two different OSD informations
simple and expanded
Press 2 x OK button
Black Hole 2.1.7 MultiBoot
WHAT IS NEW
  • New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
  • New skin MX i6p By Matrix10
  • Vu+ drivers 20150623
    - Fix tuning problem(AVL6211, duo2, solose)
    - Improve vtuner(satip support)
    - Fix scrambling bit in recording
    - Improve transcoding
  • Xbmc Support 576/720/1080 resolution
  • Updated Vuplus-Blindscan
  • Updated HbbTv
  • Updated WebManual
  • Added Sat>Ip Client
  • Included UiPositionSetup
  • Removed MeoBoot
  • Added OpenMultiBoot
  • Updated Lcd4Linux
  • Updated MediaTree (usb tuners drivers)
  • Fixed random socket error
  • [ScanSetup] fixed error on complete scan with T2 tuners
  • [ScanSetup] fixed TT3L10 automatic scan problem
  • [unicable] support JESS(EN50607) and update unicable.xml
  • AnimationSetup: set default to animations disabled
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Installed the new image & its working fine but facing one issue, i installed openpli, open spa in open muliboot & they work but I cannot connect them to internet using wifi, is it because of new drivers? in open blackhole image multiboot works like a charm... can there is any solution to wifi issue?
