Hi Can anyone help me, apologies if i am putting this in the wrong place.
I have a VU duo running 2.0.2 rev. D
I have 2 questions : i have added a 2TB HDD so that i can watch movies that i transfer to it, but when i play them after about 10-15mins its starts to bring up the loading icon and then the movies go into slow motion and freeze. I have to turn the box off from the back for it to respond.
The other question is that is there anything called blank scan? i am trying to find out if there is a way of updating those channels which has a frequency change automatically?
Nobody will answer to you for 2.0.2 D question in 2.0.8 thread .
So, update to 2.0.8 and try again your HDD.
Blank scan? Do you mean Blind Scan (as I remember, not supported by Duo) or FastScan (has to be supported by provider)?
Thanks BH lover, i went through this process when i first installed the HDD, but there have been a bit of recordings since not much though. I will try this again over the weekend and transfer movies and try again.
I will let you know how i get on.
thanks again.
regards,
@Tushar Patel : Before formatting HDD try to remove stuff you don't need from BH Spped Up Panel - Blue>Blue>BH Speed Up, create a Swap file on USB stick and try again.
DD freeze and blocks such as Tushar Patel in movie playback. mkv 1080. other avi. divxx or no concern. I think here is the player that does not support the video stream. I have well formatted and mounted again DD. bh 2.08 flash updatée that advise me please. thank you.
hello
after a lot of research and have tested on OpenPLi the same symptoms persist. Return to BH 2.09. here can not come from quality. mkv or DD .. I stopped to look for the solution, if a mkv. plant, I delete.
