STB
It simply does not work or at least it doesn't on my box on the latest version of Blackhole 205.....
The tuner is an AVL2108.
As Blackhole runs Blindscan from a plugin it green screens. Can someone tell me if there is something I could run to get rid of this issue. Some sort of kwargs error
I have tried this in Vix and it runs perfectly. I'd rather use Blackhole. Infact the reason I come back to Blackhole is that USB DVB-T works out of the box. That and the Matrix skins makes it 10 times better than Vix.
If the epg updating could be streamlined (its buggy) and requires constant manual downloading and the Blindscan issue was solved I would be a happy bunny.
Thanks
Thanks
