Blue circle on when on a channel?
I'm sorry to say this but i had the same problem with my brand new solo 2.
Turn out i had a clone.
This link only shows how good the clones are at this moment. Mine was exactly as an original outside.
Only difference for the actual original i have were:
- It had a sticker with a "no link to clone sites" on top of box ( is a clone images website )
- The remote control had a loud click in the center arrows + ok button . ( vu+ remote controls don't have any clicks like mouse buttons )
- The peel off plastics where different.
Please check with original plugin (http://www.vuplus.com/pressNewsContent.htm?idx=37&pagenum=2)
I returned mine and bought a original this time.
Good luck with that.
Hi,
My case is the same. The seller gave me your web "no link" But the images don´t work.
I sent my serial number to VU+ and they confirm me that my STB is Clone.
I have tried several images, but the only good image is BH 2.0.8 . With this image, it works fine.
I ask for refund and send the STB to seller, but they don´t accept, then I will use it.
Bye
Hi,
My case is the same. The seller gave me your web "no link to clone sites" But the images don´t work.
Bye
Then you lost the support on this forum.
We do not give support for clone.
Bye
I can 't understand why you censored me. Great decision.!!!!
I have been scammed. That's all. Why do not help?........
Then, good luck folks.
