Booting the VU+
I can not edit my previous message.
ok, I'll try it.
Try other types of cables,,,and what Do U see at the small window at front of STB, were the green light is, what writing do U have!
Try to make serch with DCC for the new IP!
When I plug the power light turns red, then green and So it remains.
I've used other TV and cable(in another room!), But the difference did not.
Can I use my cable LAN
Also thank you for your attention.
Is it possible that i deleted files that defines the receiver is connected to the TV? (After re-installation, these files are not replaced?)
I've re-installed the Black Hole, I wanted to restore my backups then I restart it . Again, as before, is broken! Now, even with image VTI.
I'll try to install another image(ViX)!!
The clean BH image ran correctly, then you've restored a backup and after this operation the box can't start.
Maybe something wrong in your backup?
