Request "C" band blind scan
wakeelkhan
it seems that no one has the answer/solution for "C" band blind scan, therefore i request and hope that the BH team will add this plugings in the next upgrade/image.
paolino
Vu+ User+++
I don't have C-band LNB, so I can't test. Could you explain better, what doesn't work? Entry fields for frequency range?
wakeelkhan
Yes I watch URDU language channels on Paksat R1, Asiasat S3 & Intelsat 20. sometimes there are new frequencies or some up & down. if you use blind scan, it adjust & search exact freq. SR & FEC by itself. as i'm using other receiver like StarTrack & delta DV 362 proton software. very easy & friendly.
wakeelkhan
paolino
Vu+ User+++
OK, but you still didn't write, what is not working. You are not able to install blindscan plugin?
wakeelkhan
no, i'm using blind scan for "Ku" band like nilesat. yahsat, hotbird & badr are working perfect but "C" band is not able to search blind scan.
i want blind scan plugins to be upgraded to scan/search "C" band same as "Ku" band.
