Cablescan blackhole
For cable scan Pli way you can also use Open Black Hole image.
If I remember correctly you have to install additional cablescan plugin from system plugins.
I have exact the same problem as Mathijn.
But i can't find the cable scan plugin, can you provide me that?
Im not using Cable now if I remember well you can try in Open Black Hole image
In the cable tuner configuration put yor network example ID 05555
Select Provider to scan >> Ziggo region
SAVE
Then you go to the Manual Scan
Choose your cable tuner
Set scan to Complet
SCAN
If you like to scan only one transponder
you have to choose Type of scan User defined transponder
and config all params.
Same here 2 for Telenet Belgain cable with all Open based images there's is no problem even with OBH, only with with BH and VTi you don't get all the channels.
I found sollution:
1. In Tuner Configuration:
Configuration mode: enabled
Used service scan type: Provider
Provider to scan: ZIGGO Zuid (NL)
2. In Manual Scan: select
Type of scan: complete
Network scan: yes
Clear before scan: yes
Only Free scan: no
4. Press OK for scan
Result 290 channels.
I found sollution:
Network scan: yes
Only Free scan: no
Tryed those settings also before coming not furhter then 170 channels instead of the 300 i must get
