Cannot set up Wireless Access Point
I gave a problem with setup wireless on my duo2: i will show all pic , hoppe you will see how or what have to do.. but also have to say dhat happend just on BH but not on OBH ..PIC-3.jpg PIC-4.jpg PIC-5.jpg PIC-6.jpg PIC-7.jpg PIC-1.jpg
If this is your problem, you can not log in to the network..?
With Black Hole image you can not use a password with symbols.
Use numbers and letters .
Hi Matrix, ofcourse i do givit password but still not working , only on OBH ..Afetr setup Wireles LAN Setup i go to Network to adapter settings LINK is bllack on adaptersetting the canot get configuration i dont know why? sorry about my Language,,
If I'm not 100% sure
what is your problem and what image and box you are using.
Box with built-in WiFi ?
If you use OBH then it has to work (tested with Duo2 ,Ultimo 4K)
If you use BH then you must use a password without a symbols (tested with Duo2 ,Ultimo 4K)
In both images WIFI works.
What is your problem
Describe exactly ?
No wifi login problem
No local connection
No external internet connection ??
