Caution! Vu+ Clone
Hi guys... possibly a new Duo2 clone is out?
On that website cloners have also released a Black Hole 2.2.0 for their Duo2...
Of course I'm not going to post the link....;)
Caution! Vu+ Clone
Dear partners and Customers,
Vu+, unarguably the leading supplier of Linux based set top box, works relentlessly to make sure the utmost quality that you expect us to achieve. This has been the integral part of the whole operations in developing and manufacturing.
However, we recently learned that a clone of Vu+ SOLO could now be traded through illegal transaction routes from China. In responding to this grave situation, we assure you that we will take all possible legal measures to ensure that such pirated copies of Vu+ products be not traded freely. Furthermore, we have already begun a technical process via which to upgrade the algorithm of system security implemented in all Vu+ products soon.
When this upgrade is put into place, no pirated copies of Vu+ products will work. While we sincerely ask for your unilateral support in dealing with this serious matter, let us state the following aspects so that you can inform those who might be interested in Vu+ clones.
1.No software update will be possible.
2.The hardware stability of clone is very questionable.
3.No repair support will be offered for clone boxes.
Also, please be noted that SOLO clones have several points that are different from the genuine SOLO as below:
We would be sincerely grateful if you send us email ( support@vuplus.com) on any information regarding how these clones are actually traded by whom. We believe that fighting against pirated copies of Vu+ products is not just for the benefit of Vu+ only but also for all customers of Vu+ as a whole. Thus, we once again wish for your unilateral support.
Best regards,
Vu+ TEAM
you only need to look here AliExpress
Caution! Vu+ Clone
Best regards,
Vu+ TEAM
tnks for warning
I am trying to register my vu solo via the return the love event but I am not allowed to input the first letter "E" of my receiver...
All default serials should start with "M" as I can see.
I am using VU black hole image.
The receiver is definitely an original one as it comes from a greek authorized reseller...
Is there anything I can do to register it or the return the love event is only for VU uno and Duo?
Thank you
merci de l information moi j ai acheter un vu+solo2 de angleterre chez word sat j espere qu il est d origine
salve ho acquistato un decoder vu+solo2 di seconda mano senza scatola mi è stato garantito la sua originalità ma ho un dubbio.
monta un immagine B.H. 1.4 ho provato a montare un immagine b.h. 3.0. presa da questo sito alla fine del caricamento mi a dato 2 lettere + error
ora usando una bh 1.7 il decoder è riapparso come prima di incominciare a montare altre immagini tutte senza esito. cosa potete dirmi vi allego anche delle immagini del decoder
AF1QipN6r5nfTQNL_gJJwNKzMIHHspuuNY2_uEQu80N0
grazie
