lucaxx88
The process is the same for flashing ... you have to remove all your usb devices ...
You are trying it on a Duo2, right?
Yes and not work.
I try also on a Vu + zero but nothing...(it's different on zero?)
Thanks for this helpful post, I think it should be made sticky somewhere on the front page.How to make and change the splash screen!
Just one little suggestion though, yellow fonts are almost unreadable when using white theme as seen in the attached pic, unless the complete sentence has been selected with mouse.
Preferably blue, or any other color would be fine to highlight some parts.
