channel number greater than 9999
ahmeddriss
Hi
how can I search for channels whose number is greater than 9999 in blackhole image with the remote control .. Thank you
AlexWilMac
Moderator
So, you need to delete some useless channels from your bouquets: I'm sure you have some to consider useless :).
I'd need all my life to use more than 9999 channels...
AlexWilMac
Moderator
P.S. Anyway: I've just tried in OBH where, after having set the preference of using 5 digits, you can digitize number greater than 9999.
Actually, it was needed to create duplicated bouquets in order to have so many channels, because 3 satellites weren't enough to have more than 3000 channels ;)
But there are also this IPTV services full of crap channels... :D
ahmeddriss
Thank you for your answers ....... yes I use iptv service and my favorite channels have numbers greater than 10000 and I cannot delete all channels
AlexWilMac
Moderator
Not all: maybe a couple of ones which are useless? If you can't, then there's no solution, at least using BH.
Matrix10
It seems to me that you have never used DreamboxEdit for making your own lists and editing.
10,000 channels is of course a huge number that you will never use.
So the solution for you is to edit the list as you wish.
Search the forum, the net and YouTube for how to use Dreamboxedit.
