chipset rtl 2832
city
good day all, can someone tell me if the driver of rtl2832 is included in the new bh 1.7.7.
thanks in advance.
angelofsky1980
BlackHole Driver Specialist
thanks in advance.
It's included into BH the LinuxTV version of that driver.
It's not guarantee that you device works ... What device do you have?
city
good day Angelofsky, did u confirm if chipset rtl 2832 works in bh 1.7.7 as we discussed before.
thanks for your great work.
Alexis
Can u tell me please about Terratec RTL-USB Kit, DVB-T TV , RTL2832U & E4000 Tuner ?
I found this from e-bay and i want to know the compatibility with solo2 before i get it.
angelofsky1980
RTL2832 chipset and E4000 tuner are supported into BH 2.0.1 and newer .... But I cannot assure if the tuner works.... I've bought a RTL2832 with an E4000 tuner inside and it's correctly detected and operational ......
Sotos65
I 've got the same stick (I bought it mainly to use it with SDR software), it is detected in BH 2.0.2 on my Uno, but it doesn't seem to scan anything. I wonder if there something I can do to make it work properly...
Sotos65
I think the settings are ok. There is only one live DVB-T transponder in my area right now, at UHF 39 (618 MHz). I have reception in my tv, in my pc with the same DVB-T stick and an internal PCI card, but nothing on Uno so far both with automatic and manual scan.
Alexis
Sotos65
The scan was with an external antenna and the stick works fine on my pc. Btw, the results are the same also on OpenPLi 3.0 and OpenVix 3.0, the stick is detected but scans nothing...
angelofsky1980
Ok I can test the RTL2832+E4000 device with a Vu+Solo
angelofsky1980
I've tried a Realtek 2832 with E4000 tuner inside and works properly (Vu+Solo box + BH 2.0.2 Rev. A).
I use a protable antenna and detects only 30 DVB-T services (Vu+Uno internal tuner detects over 250 services on the same place with the same protable antenna).
