great works for meTry this one
fixed some bugs in coding (bug in CoolTVGuide_1280.xml color definitions)
and bug in png files converted from true color 24 bit (Not supported in Black Hole image) to True color + Alpha 32 bits
Hi
i am using VU solo 4k BH image skin MXHQ10 but coolTVguide does not work
I can see it loading for a moment (a second) and then it disappears
I have tried adding the file amendments as in this thread but no change
Any help appreciated
Found the solution in a previous thread
where is that?? thanksYou can try from Black Hole image server
Cool Tv Guide v7.6.0 (IPK Packages)(Black Hole E2)
with hd modification.
If someone has better skins they can post.
sorry will it work on openpli 4?
