Cool Tv Guide V.5.0.0 by Coolman
in the latest version of cool tv guide - there is no path setting for the picons.
when i install the picons into /media/usb/picons/...
I do a restart, and the picons still dont show. How is everyone else getting theirs working?
i would rather use the usb path.
thanks
It should work without any adjustments, your picons are shown corectly on the infobar?
You can check through the setup if: Shown Picon is set to yes.
hi, the infobar isnt showing the picons either. Does it default look at the USB or the HDD? - in the previous versions the path could be set
In BH default is in media/usb/picon.
Try to check you usb is right mounted in blue panel
Go to BH image server and download the picon you need!
If U have an USB ,it will directly go there!
And then check the Cool-Tv setup , like the following:-
RgdZ
a911
Hi
I have installed the ipk manually and it says its installed ok. However when i reboot my box its not showing in extensions or as a plugin?
I have configured this on dreamboxes no problem in the past.
I have a duo running black hole.
Any help greatly appreciated
Cheers
Hi
Cheers
Down load , the latest plugin, from the BH Image addons server : (green>yellow)!
I installed v6 of coolguide, but it has reassing color buttons,
pressing green give me the epg,
do you know to uninstall without green yellow??
btw also it has changed language from UK to Greek,
damn I have to flash again the box..
any help..
any help..
1st : press the Cool TV plugin>> by choosing the Cool/TV buttons on the menu, U can make a setup to your desire!
2nd : Do not understand , what changed from English to Greek ?
Hi guys,
Trying to install on a Vu+Solo2 from its plug in menu but cant get it to work. I have installed and re-installed a few times and tried to configure in the app but to no avail. Maybe it is how my usb is configured (mounted as USB)?
Please help because it is a cool plugin.
Malvec
Nothing to do with your usb mate
Newest version of this plugin is 6.1 from the feed (green > yellow > addons download manager)
to configure - press green and select plugin
If you've BH179-3 and no remote control buttons associated with the plugin just press and hold epg button - you will see more option to run this plugin
