Hello, my box crashed with normal use, perhaps it was recent update the epg when I enter in dlna browser and when exit I push to enter again and green screen, this is the crashlog:
<?xml version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Sat Jan 16 23:26:12 2016</crashdate>
<compiledate>Jul 7 2015</compiledate>
<contactemail>crashlog</contactemail>
<skin>skin.xml</skin>
<sourcedate>2015-07-07</sourcedate>
<branch>master</branch>
<rev>2.1.4-67-g9ccd154</rev>
<version>3.0.0</version>
</enigma2>
<image>
<kernelcmdline>ubiroot rootflags=sync bmem=192M@64M ubi.mtd=rootfs rootfstype=ubifs root=ubi0:rootfs libata.force=1:1.5Gbps</kernelcmdline>
<imageversion>
<![CDATA[
version=1000201507071605
</imageversion>
<imageissue>
<![CDATA[
BlackHole 2.1.7 %h
</imageissue>
</image>
<software>
<enigma2software>
<!-- Cannot allocate memory -->
</enigma2software>
<dreamboxsoftware>
</dreamboxsoftware>
<gstreamersoftware>
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
nigma!
WARNING: EPG Cache is corrupt (eventData::~eventData), you should restart Enigma!
[EPGC] stop cleanloop
[EPGC] 24157985 bytes for cache used
[EPGC] 512380 events read from /media/hdd/epg.dat
nr_read 2032 nr_write 8285
sum 10317 prev_sum 9548
hdd was accessed since previous check!
[IDLE] 0 300 False
sum 10317 prev_sum 10317
hdd IDLE!
[IDLE] 0.147320985794 300 False
hdd IDLE!
[IDLE] 0.294672966003 300 False
It's now Sat Jan 16 23:23:57 2016
[timer.py] next activation: 1452983137 (in 99600 ms)
[timer.py] next activation: 1452983137 (in 99599 ms)
hdd IDLE!
[IDLE] 0.445564985275 300 False
action -> InfobarMenuActions mainMenu
loading mainmenu XML...
BhRed BhRedp_main
BhSettings DeliteSettings
PluginBrowser PluginBrowser
BhAddons DeliteAddons
BhEpgPanel DeliteEpgPanel
TimerEdit TimerEditList
allocating new converter!
nr_read 2032 nr_write 8293
sum 10325 prev_sum 10317
[IDLE] 0 300 False
[EPGC] start cleanloop
[EPGC] 41184158 bytes for cache used
action -> OkCancelActions ok
okbuttonClick
action -> WizardActions back
okbuttonClick
warning, skin is missing element green in <class 'Screens.PluginBrowser.PluginBrowser'>
action -> WizardActions ok
action -> WizardActions down
unknown action WizardActions/down! typo in keymap?
sum 10325 prev_sum 10325
hdd IDLE!
[IDLE] 29.9999790192 300 False
config : [/media/upnp/][10000][10000]
updated device list!!
action -> ShortcutActions green
[DLNAClient Plugin] Info >> prepared command : modprobe fuse
child has terminated
pipes closed
[DLNAClient Plugin] Info >> prepared command : djmount -o allow_other -o iocharset=utf8 /media/upnp/
poll: unhandled POLLERR/HUP/NVAL for fd 58(16)
pipes closed
clear task!!
hdd IDLE!
[IDLE] 60.000647068 300 False
[EPGC] 41174793 bytes for cache used
It's now Sat Jan 16 23:25:37 2016
[timer.py] next activation: 1452983237 (in 99998 ms)
[timer.py] next activation: 1452983237 (in 99997 ms)
action -> DirectionActions downUp
unknown action DirectionActions/downUp! typo in keymap?
Looking for embedded skin
[Picload] setPara max-X=1860 max-Y=1020 aspect_ratio=1.000000 cache=0 resize=1 bg=#00000000
before: 1
after: 1
[Picload] decode picture... /media/upnp/DESKTOP-LDNQQG9: David:/Imágenes/Carpetas/Imágenes/merry christmas.bmp
before: 1
[Picload] decode picture... /media/upnp/DESKTOP-LDNQQG9: David:/Imágenes/Carpetas/Imágenes/splash_cfe_auto.bmp
action -> OkCancelActions cancel
[Picload] decode thread ... got quit msg
thread joined 0
hdd IDLE!
[IDLE] 89.9999010563 300 False
before: 1
after: 1
before: 1
[Picload] decode picture... /media/upnp/DESKTOP-LDNQQG9: David:/Imágenes/Carpetas/Imágenes/8be4255004483aa9f5382d47ea90702e.png
thread joined 0
action -> WizardActions up
action -> DirectionActions upUp
unknown action DirectionActions/upUp! typo in keymap?
before: 1
after: 1
before: 1
[Picload] decode picture... /media/upnp/DESKTOP-LDNQQG9: David:/Imágenes/Carpetas/Imágenes/merry christmas 2.bmp
thread joined 0
File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action
res = self.actions[action]()
File "/usr/lib/enigma2/python/Screens/PluginBrowser.py", line 59, in save
self.run()
File "/usr/lib/enigma2/python/Screens/PluginBrowser.py", line 63, in run
plugin(session=self.session)
File "/usr/lib/enigma2/python/Plugins/Extensions/DLNABrowser/plugin.py", line 905, in main
session.open(DLNADeviceBrowser)
File "/usr/lib/enigma2/python/mytest.py", line 312, in open
dlg = self.current_dialog = self.instantiateDialog(screen, *arguments, **kwargs)
File "/usr/lib/enigma2/python/mytest.py", line 247, in instantiateDialog
return self.doInstantiateDialog(screen, arguments, kwargs, self.desktop)
File "/usr/lib/enigma2/python/mytest.py", line 278, in doInstantiateDialog
dlg.applySkin()
File "/usr/lib/enigma2/python/Components/GUISkin.py", line 112, in applySkin
self.createGUIScreen(self.instance, self.desktop)
File "/usr/lib/enigma2/python/Components/GUISkin.py", line 47, in createGUIScreen
f()
File "/usr/lib/enigma2/python/Plugins/Extensions/DLNABrowser/plugin.py", line 765, in layoutFinished
self.updateGUI()
File "/usr/lib/enigma2/python/Plugins/Extensions/DLNABrowser/plugin.py", line 838, in updateGUI
if self.isRunning():
File "/usr/lib/enigma2/python/Plugins/Extensions/DLNABrowser/plugin.py", line 831, in isRunning
ps_str = os.popen('cat /etc/mtab | grep djmount').read()
OSError: [Errno 12] Cannot allocate memory
(PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x21949b8>>,('WizardActions', 'ok')) failed)
</enigma2crashlog>
<pythonMD5sum>
</pythonMD5sum>
</crashlogs>
</opendreambox>
Thanks.
<opendreambox>
<enigma2>
</enigma2>
<image>
<imageversion>
<![CDATA[
</imageversion>
<imageissue>
<![CDATA[
BlackHole 2.1.7 %h
</imageissue>
</image>
<software>
<enigma2software>
</enigma2software>
<dreamboxsoftware>
</dreamboxsoftware>
<gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
nigma!
[IDLE] 0 300 False
hdd IDLE!
hdd IDLE!
hdd IDLE!
BhRed BhRedp_main
[IDLE] 0 300 False
okbuttonClick
okbuttonClick
hdd IDLE!
pipes closed
pipes closed
clear task!!
hdd IDLE!
before: 1
after: 1
before: 1
thread joined 0
hdd IDLE!
before: 1
after: 1
before: 1
thread joined 0
before: 1
after: 1
before: 1
thread joined 0
self.run()
dlg.applySkin()
f()
self.updateGUI()
</enigma2crashlog>
<pythonMD5sum>
</pythonMD5sum>
</crashlogs>
</opendreambox>
Thanks.
