As barryr said, you have to install "moviecut", because "cutlisteditor" only sets the marks. "Cutlisteditor" is part of image, but is useless without "moviecut" or a similar plugin. You should install "reconstructapsc" too. I guess, this plugin builds a new raster????? (some of the files with name of the record on your hd, but with other extensions), if you have stopped the recording not regularly or if you were forced to kill the corresponding marker files, if no normal function of the cut process after wrong inputs of you with the cutlisteditor were possible or markers could not removed anymore.
