AlexWilMac
Moderator
I found out that it's impossible to edit and cut 4K recordings and this with BH 3.0.2I, OBH 0.6 and OpenPLI.
When I try, moviecut gives me an error about .ap file but the problem it's not caused by movietools.
The reason is that simply there is NO .ap file!
Obviously, I also tried to reconstruct .ap .sc by the specific tool but it is not possible just because, I think, Solo4K is not able to produce the .ap file or if it creates, is of zero length.
This prevented me to cut, for instance, the "I medici" broadcasted in 4K (and I initially thought it was a decoding problem but it isn't because it happens also with FTA 4K channels) and it's a pity.
But the problem is not secondary, in my opinion: what's the purpose in having a 4K decoder with ability to cut all recordings but 4K ones?
