D-Link DWA-123
@Eragon: I tryied a normal wireless router, it doesn't work unless it's open access, I tryed the wifi dongle of a friend (O-link) and it worked with my android phone AP :(
@angelofsky1980: so the wifi.txt that I posted doesn't help?
In the first post daryou said that his wifi dongle works if the wireless network doesn't use any security protocol.
In this case might it work if no drivers were included in the BH image?
IMHO there is a security protocol incompatibility with the implementation of the android hot spot (generally very poor...).
To be sure daryou should try to connect the box with a normal AP/wireless router.
I've read the debug file and around the entry for wifi dongle there is not a driver name .... so the device is not detected by Vu+ box
In fact BH 2.0.8 doesn't detect my dongle, but the BH 2.0.1 does, I posted the two wifi.txt files, the first with 2.0.1 and the second with 2.0.8
In the back of the dongle I read: H/W Ver.:B1 F/W Ver.: 2.00
I repost here the debug file (with BH 2.0.1)
Thank you for your help.
Probably into old BH 2.0.1 it was used another version of the driver according to chipset manufacturer releases .... We will restore the support ASAP
Thank you very much, I downgraded to 2.0.1. By the way, what do you think about being able to use my dongle with open access AP but not with protected AP?
