Default picon
Blaze
Mounted my usb stick trying to put the blackhole picots on to the usb stick nothing showing in the image strange one the picons have loaded to the usb stick I can see them on my computer but nothing showing on my box with the usb connected any help on this
newgolfer
Vu+ User+++
Inside your Usb there must be the folder called picon (if it doesn't exist you create it) in which you will put your picons.
Blaze
iv done all the above u told me no look i thought there might be a down load on the web defalt picond black hole were i could down load them
