default to graphicalepg
johnsilvo
I've changed from Openvix to Black hole and the only gripe i have is that to get to graphical EPG you have to long press epg and then select the option whereas in Openvix it came up with a single short press. Is there a way to change this?
AlexWilMac
Moderator
The question you ask is not just about OpenVix and BH: it's one of the differences between open projects, like OpenVix but also OpenBlackHole and all the other open images, and the vuplus code-based images, like BH and VTi: the complete keys customization is typical of open images.
Under BH you can use some plugins, like SetupQuickButton, but you won't never have the same degree of freedom over the key assignment.
AlexWilMac
Moderator
In case... to OpenBlackHole ;)
I don't think you'd buy a car only based on its colour, would you? An image is an operative system and cannot be chosen only for such a secondary detail. But if you are accustomed to the philosophy of OpenVix, I'm sure you'll find OBH even more interesting.
