Solo2 Dialog TV HD TV 11550V28800/S2/8PSK not scanning
maxious manohar
VU+ solo2 couldn't scan the HD tp for dialog tv in intelsat 12 , 11500V/28800/V/S2/8PSK
there is no problem in the amiko SH8900 tuner
Mick12334
Moderator
He had it correct in the title, of the thread, but wrong in his post, so I wonder which one he is trying to enter.
This might be a reception issue, so please post your general location, and size of your dish.
Can you also please provide your signal quality readings, for other Digisat channels, on 45E.
maxious manohar
Sorry the TP should be 11550V/DVB-S2/MPEG-4/28800-3/5,8psk. As i told you earlier that i don't have any issue with Amiko SHD8900, this is a problem in prism cube as welll.
I have a 8 feet prime focus with inverto quad lnb in jakarta indonesia.
Mick12334
Moderator
What are your signal quality readings for the SD,Standard Definition, channels?
11468 V 27689, 11591 V 27689, 11632 V 27689 and 11673 V 27689
maxious manohar
signal quality reading vary between 56 to 62 for those SD TP's.
this is a known problem for many boxes, i have the same problem in manhattan passion LX1920-II .
i heard dm800 works and other dm models cant scan this tp .
Mick12334
Moderator
It sounds like a dish problem, not a receiver problem.
Different receivers have different tuners, some are more sensitive than others, so can lock on to a weaker signal. Your SD signal readings are quite low, and HD channels are more difficult to pick up.
You could try adjusting your dish, to see if you can improve the signal, and check the beam maps, to see what size dish is required, in your region.
http://www.lyngsat-maps.com/footprints/Intelsat-12-India.html
maxious manohar
As i mentioned earlier this problem is faced by many people in the country of the package itself ie. Srilanka. Its widely documented many boxes except few boxes like amiko couldn't tune this TP. I want to to if there is any software fix for this issue, but i am not hopeful since the amiko shd8900 i have tried in many enigma 2 distor like openatv, openvix, open pli and doesn't have any issue for this TP. Is there any issue with the tuner or some config done to the tuner in the firmware level?
angelofsky1980
BlackHole Driver Specialist
Report this issue directly to Vu+ (www.vuplus.com)
Mick12334
Moderator
Lyngsat has 2 listings, for the same frequency, and polarity, on that satellite, 45E:
11550 V 30000 DVB-S2 8PSK 3/4 Europe Beam
11550 V 28800 DVB-S2 8PSK 3/5 India beam
Mick12334
Moderator
have you checked your Satellites.xml list?
Using FileZilla, login, to your receiver, go to var, tuxbox, right click and select the view/edit option, open it with Microsof Ecel, if you have the Office program.
maxious manohar
i assume you expect to see the channels for the TP in that file, the issue we have is that the box didn't even lock this TP.
i believe Amila Perera also has the same issue. This kind of issue was reported for the solo model ( not solo2 ) for symbol rates such as 30000. There was a FPGA patch for this problem to make the tuner lock high symbol rate tp for DVBS2. i am thinking this TP also would require such FPGA patch or driver upgrade since its a basic tuner firmware or tuner hardware issue.
oldgraf
I see all day transponders with 30000 symbol rate. All tr. with provider have this rate - DVB-S and DVB-S2.
Solo2 and OBH
