avishafrir64
What is the difference between SOLO , SOLO SE and SOLOE SE V2 ?
Is the black hole solo image compatible for all 3 of them ?
http://www.vuplus.com/sub/sub0109.php
The v2 also supports a twin tuner, whereas v1 will only support a single tuner.The VU+ Solo, the original, is a different model to the VU+ Solo SE, and VU+ Solo SE v2.
You can compare the figures on the VU+ website:
Code:http://www.vuplus.com/sub/sub0109.php
The VU+ Solo SE, and Solo SE v2, use the same image, as they are basically the same receiver, only the v2 version has more flash memory, all other VU+ models have their own version.
The solo2 is the older box, of the 2.Sorry about the SOLO V2 , I wrote it by mistake , I meant SOLO 2 and after posting did not know how to correct
So if I am not interested in cable/terrestrial tuner and both of them can record on Hard Disk internal or external it seems they are both almost the same ?
There is no advantage to SOLO2 at all beside an additional USB and panel display ?
