I have tried that also. Switch the box of (even with the power back on the box). But same behavior.Does this happen all the time? You tryed switching your box off at the back switch then back on? If these don't work then no option but to reflash
Have you mounted your hdd by devices manger?Have Vu+ Duo2 With BH 2.1.3.
When press on record button remote key my box crash (green screen) and the restart.
Any idea what to do?
Yes.Have you mounted your hdd by devices manger?
However, you should find crashlog files in /hdd.
I have tried to find any reason in the crashlog. Show a lot, but I can't find any reason.Have you mounted your hdd by devices manger?
You can upload your last crashlog here.I have tried to find any reason in the crashlog. Show a lot, but I can't find any reason.
Are there any place to send logs like this to get any help.
I will not go back to OpenPli.
Maybe the issue is due to a plugin.
Uninstall permanent timeshift and verify if instant recording works.
I will. But OpenPli (that I previously use I not need any plugin for timeshift). Why BL not have any time shift by default ?Since it's a plugin issue, you should ask to his autor to solve it.
What are you saying?I will. But OpenPli (that I previously use I not need any plugin for timeshift). Why BL not have any time shift by default ?
Yes, I know. But Openpli has this feature without press pause. You can configure to start timeshift after 5-30 sek.What are you saying?
It's a feature that always has been present.
To activate time shift you only need to press the pause button.
It seams easy to press pause every time you swap channel. But you don't.
Missing this feature.
As I wrote in the beginning of this tread, I have problem with just this plugin.Permanent timeshift is an addon plugin. So install it into BH and you have fun.
