DMConcinnity-HD_1.0.2-BH-1.4.x
capa
Vu+ User+++
hallo
here the fix of my old Mod of DMConcinnity HD. Please Test it on VU+ Receivers
- DMConcinnity-HD - BH Green/Blue/ect. Pannels
- Only BH Images 1.4.x and "ONLY" for BH Images, no other
- No Python Converters, works only with BH software
as first ony for testing, please report Bugs if you'll find which :)
at the moment only MANUAL install file, unzip and copy over FTP to /usr/share/enigma2
  • DMConcinnity-HD_1.0.2_BH-1.4.x.zip
  • DMConcinnity-HD_1.0.2_BH-1.4.x_bh.tgz
a911
The BH Lover
Hi capa nice 2see Uhere,
I do not like to use mod skins,,, however for U will test and report!
Good job!
Can U make it into an ipk file, please!
Rgdz
a911
Ruben
Hey buddy, I do not go, and I really love this skin, I leave here the logcrash
Thank you very much for your work
  • enigma2_crash_1294859501.rar
Ferbius
BH Lover
check out this great font
[FONT] adding font /usr/share/enigma2/DMConcinnity-HD/fonts/HandelGotD.ttf...FATAL: failed: Operation not permitted
capa
Vu+ User+++
Good job!
Rgdz
a911
;) mods of mods of mods are not really usable and not really needet, but mod's of CVS skins are not really bad.
thx for testing
@Ruben, pls check if you have copied this font too, maybe some files filed to copy
capa
Vu+ User+++
Good job!
Rgdz
a911
by the way, this ist not a MOD, this is DMConcinnity, i don'n use modified skins.
I take only CVS based skins, and add only BH stuff+addons.
So this is pure DMConcinnity-HD CVS + BH stuff.
No problems with code snippets of other Images , or external Python code or converters.
But you should know this skin for BH, i posted it last year in summer on the old DreamElite board
thx for testing or using ;)
Dzoni
BH Lover
Could You change colour font for ecm info, because is bad visual look, or put black tape under,that can see better this font ?
And this "dreambox" change to "vu plus" because if this skin for Vu need to put "vu plus".
Ruben
Ok, everything is perfect, I simply renamed the file " DMConcinnity-HD_1.0.2 " to"DMConcinnity-HD" and that's it worked perfectly. Very thx.
a911
The BH Lover
Hi capa
can U show me how/where to put the skin folder , using DDC!
thanx!
a911
capa
Vu+ User+++
The skin folder must call "DMConcinnity-HD" and all skin files into them.
simply rename your extracted folder to this name and copy to /usr/share/enigma2/
a911
The BH Lover
Tested..it crashed,,deleted,,,evry thing is back 2normal....;)!
Thanks capa!
>>Artorius<<
>>English Admin<<
I have packed the file for auto install, tested on BH 1.43 on Vu+duo
I have crash as soon as GUI is restarted, only way to recover is to delete the folder.
Here is crashlog for you Capa
PS If you need files packing just let me know.
Regards
>>Artorius<<
  • enigma2_crash_1295124052.zip
capa
Vu+ User+++
The Skin dont crash . If you unzip the Folder you have to rename the skin folder from "DMConcinnity-HD_1.0.2" -->>> "DMConncinity-HD"
The Skin folder in Image is calling /usr/share/enigma2/DMConccinity-HD !!
I've repack the Skin, so you should dont get errors no more
pls unzip the File, and compy the Folder "DMConcinnty-HD" to your box
@>>Artorius<<
If you'll build the package, take only the DMConcinnity-HD folder into autoinstall package
or ask ^^corrado^^ pls.
regards
capa
Vu+ User+++
please check the Right name of the Skin folder, the name on /usr/share/enigma2/ must be
DMConcinnity-HD
I dont have a VU+, but Morpheus1969 has tested it and told me all is OK
regards
here the Skin folder with right name
  • DMConcinnity-HD_1.0.2_BH-1.4.x.rar
