mr.strauss
dreamboxEDIT 5.1.1.0
5.1.1.0
- added parental lock for streaming services (hope I didn't break anything with that change)
- added support for streaming services with missing #DESCRIPTION line in userbouquet files
- added streaming services to the userbouquet import function
- added automatic streaming URL conversion for "StreamingStar's URL Helper" format
- added ZAP to service before streaming to the streaming options panel (useful for single tuner receivers)
- changed VLC streaming behaviour, VLC is disabled by default now, activate it in the streaming options panel
Note: VLC 2.0.4 is recommended, any other version may or may not result in error messages
the VLC installation directory set in the options panel is now used first and
the automatically detected installation directory of VLC from the registry is used afterwards
- fixed error message when clearing all "N" and "X" flags while using filter "only new"
- fixed error message when clearing all parental locks while using filter "only locked"
- some minor fixes
Thx dhwz
5.1.1.0
- some minor fixes
Thx dhwz
