dreamboxEDIT
The mac version doesn't work with OS X El Capitan 10.11.5 (15F34), any time I try to use a browse button it hits an exception.
I using the black hole 0.6 open blasck hole image the dream box edite 6.1.2.0 isn't connecting to my duo 2 strange my dcc is working ok
DreamboxEDIT 7.0.0.0
Changelog:
7.0.0.0
- added support for editing of non-TS streaming services with full reference
- added copying of existing service reference to an IPTV service (hold down CTRL while using drag&drop)
- added rename of IPTV services to context menu
- added automatic IPTV service name formating
- added picon support for streaming services with full reference
- added picon setting for using 4097_... service ref for filename (if needed)
- added service type indicators (SD, HD, UHD, H.265, Radio, Data) in front of servicenames
- added more filter options (SD, HD[H.265], UHD[H.265], DVB-T2)
- added support for DVB-T2 (only cosmetic changes, older versions already work with DVB-T2)
- added support for DVB-S2 modulations 16APSK and 32APSK
- added support for multistream MIS/PLS (fully editable in satellites.xml editor, service details, transponder edit)
- added playback of IPTV streams
- added automatic replace of invalid polarization values (some satellites.xml use polarization L/R instead of 2/3)
- added copyable service reference with colons to service details
- added insert hidden marker to context menu (enable fastscan/hidden marker support first in options panel advanced)
- added support for unknown services in userbouquets (includes former known subservices) (options panel advanced)
- added experimental option to save lamedb5 format (OpenPLi)
- added configurable buffer size for streaming player (options panel GUI)
- updated streaming player
Note: VLC 2.2.4 is recommended (32-bit only), any other version may or may not result in error messages
- improved crypto icon (encrypted services) in front of servicenames
- improved reading speed on userbouquet switch
- improved picon resizing speed
- improved marker visualization
- improved Wine compatibility (Wine 1.8.3 recommended)
- improved compatibility with "Parallels Desktop for Mac" coherence mode
- dropped support for obsolete settings format 3
- re-enabled the export of terrestrial services/bouquets in Excel readable format
- fixed hiding of alternatives view after reading new lamedb
- fixed removing alternatives if a service is removed from all bouquets
- fixed user bouquet import with hidden markers
- fixed rendering of disabled menu items
- fixed memory exception when copying IPTV services from one dreamboxEDIT session to another one
- many GUI improvements (including the new MetroUI standard skin)
- language file updates, addes missing ones to setup xe file
- minor fixes
- fixed dreamboxEDIT installer, now the registry is cleaned properly on uninstall again
Note: before reporting any bugs, please try to uninstall first if you experience any issues
if you experience any issues with the file open dialog, switch to the old style dialog (options panel general)
Changes in 7.0.1.0
- added support for real hidden markers (#SERVICE 1:832:d:0:0:0:0:0:0:0: )
- fixed autoexpand of provider bouquetlist when using create bouquet from context menu
- fixed dreamboxEDIT installer, remove all files properly on uninstall
DreamboxEDIT 7.0.1.0
( setup version attached )
changelog:
- added support for real hidden markers (#SERVICE 1:832:d:0:0:0:0:0:0:0 )
DreamboxEDIT 7.1.0.0
Changelog:
7.1.0.0
- added option to disable service type indicators in front of servicenames (options panel GUI)
- added new cleanup function for local picon directory (removes all picons not found in any user bouquet)
Note: the other option removes only picons not found in both lamedb AND user bouquets
- added High-DPI support / scaling natively without losing sharpness
- added scaling factors 100%, 125%, 150% and auto (depends on system setting)
Note: this will override the font size selection which is now only used on 100% factor
- added 64-bit build of dreamboxEDIT
Note: use VLC 32-bit for standard and VLC 64-bit for x64 version of dreamboxEDIT
- improved dreamboxEDIT installer: new accessibility options (high contrast mode, scaling mode)
- improved automatic VLC path detection for use with 32-bit/64-bit dreamboxEDIT/VLC at the same time
- improved manually set VLC path is now separately saved for 32-bit/64-bit VLC
- fixed writing hidden/numbered markers (some invalid descriptions were written before)
Thank you @newgolfer for the download file. I use DreamEdit and which is very powerful and easy to use but the upgrade link always directs to a geman website unfortunatelly I cannot read Geman (although the webpage has an English edition but it is not an full English verson. Thank you for the uploaded file.
THANK YOU TOO, it is so much hard work without supporters like you to help and make it easy to use the images for us mortals
DreamboxEDIT 7.2.0.0
7.2.0.0
  • added eServiceUri support
  • added autoscrolling on moving profiles
  • added moving multiple profiles at once
  • added switch on/off service type indicators without restart
  • added scaling factor 200>#/li###
  • improved write all linebreaks as Unix(LF) not Windows(CRLF)
  • improved MIS/PLS handling
  • improved error messages
  • fixed initial default pathes
  • fixed issues with path selection dialog
  • fixed some uncommon bug when writing markers (introduced by last update)
  • fixed assign and remove of picons in main service list
  • fixed OpenSSL libraries (x64 files were missing)
  • fixed not properly working function „Mark services not in Userbouquets with flag X“
  • fixed error on export of bouquets/services
  • fixed skipping of some completely invalid formed bouquet entries of some IPTV providers
  • fixed satellites.xml editor (transponders weren’t deleteable if confirmation questions were disabled)
  • fixed website links
  • some GUI improvements
  • OpenSSL security updates
  • language file updates
