DreamBoxEdit
lorenzo64
Changelog:
4.0.0.0
- code migration to Delphi 2007, for later unicode support
- removed XP visual styles (there were some problems after migration to Delphi 2007)
- added theming for some components
- added channel numbers in bouquet panel
- added new hints in main list and bouquet details, now with picon and service reference
- added option to assign and remove picons
- added cleanup function for local picon directory (which removes all unused picons) to tools menu
- added option for automatic picon upload to FTP window (Note: unzip command on your dreambox is required)
- added configurable per profile picon path to options panel
- added quick profile selection in statusbar
- added enhanced filter expressions (SQL style):
use % as substitute for zero or more characters (e.g. %sky% shows all channels with “sky” in name),
use _ as substitute for exactly one character (e.g. _sky_ in package filter shows channels of provider “BSkyB”Augenzwinkern
use as escape character (e.g. %%% shows all channels with “%” in name)
if you don’t use above filter characters the filters will only show exact matches
- changed TV service types defaults (now including HDTV service types)
- fixed error message when saving alternatives bouquet with parental lock
- fixed error message after reading radio service alternatives
- fixed bouquet change is now disabled while picons are loading to prevent errors
- fixed alternative service names are now written in UTF-8 instead of ANSI
- fixed alternatives are now deleted if service is removed from main service list
- fixed alternatives are now handled for each user bouquet seperately
- fixed translation problem in alternatives panel
- fixed problem with incorrect filename if you tried to add alternatives for a data service, adding alternatives
for data channels is not allowed, please set proper service types in advanced options first
- fixed keep filters when adding alternatives for a service
- fixed missing picons when using cut&paste or drag&drop
- fixed display of proper bouquet name when bouquet has been renamed
- fixed display of picons when adding services to an empty bouquet
- removed “input selection” in main service list as it didn’t work as expected
  • DreamBoxEdit_setup_4.0.0.0.zip
>>Artorius<<
>>English Admin<<
Changelog:
4.0.1.0
- fixed sorting services in bouquet panel was broken after adding channel numbers to the bouquet panel
- fixed error when sorting bouquets with cable and terrestrial services
- fixed some other functions were also broken after adding channel numbers to the bouquet panel
- fixed hour glass didn't get away after loading new settings
- fixed error message when using picon cleanup function and filename wasn't using proper picon reference format
- fixed alternatives are no longer considered as duplicates of fixed services in the same user bouquet
- fixed alternatives handling, now you can use the same service with and without alternatives in one user bouquet
- fixed blacklist entry for radio user bouquets
- fixed all files are now written in proper settings-type 4 format
- fixed auto insert markers for cable and terrestrial services
- added Enigma2 restart button to ftp window, use this button to activate any changes related to lamedb and/or black-/whitelist
use the autoreload or "reload settings on dreambox" button if you only change your userbouquets
- added sorting of profiles in options panel
- changed satellites in filter combobox are now sorted by position from west to east
- changed profile default paths to enigma2 defaults
- window state is now saved on application close, and restored when application is started
- some minor fixes
- language files updated
  • DreamBoxEdit_setup_4.0.1.0.zip
Daconi
Vu+ User+++
DreamBoxEdit-IHAD Edition 4.0.1.2
Changelog:
4.0.1.2
- fixed userbouquets with renamed services are now written in proper settings-type 4 format
- fixed problem when saving cable or terrestrial settings (some parameters were lost)
Rgs,
  • DreamBoxEdit_setup_4.0.1.2.zip
Dzoni
BH Lover
Dreamboxedit portable - NO NEED INSTALLATION.
  • DreamBoxEdit_without_setup_4.0.1.2.zip
mr.strauss
DreamBoxEdit-IHAD Edition 4.1.0.1
4.1.0.1 - fixed problem with profile selection in options panel - fixed missing parameters for cable settings after Enigma1->Enimga2 conversion
  • DreamBoxEdit_setup_4.1.0.1.zip
  • DreamBoxEdit_without_setup_4.1.0.1.zip
sonc
DreamBoxEdit IHAD Edition 5.0.0.0
Changelog:
5.0.0.0
- added completly new GUI with skinning support
- added transparency to crypto icon in main service list
- added transparency to dummy picon in bouquet panel
- added configurable color marker for selected services
- added proper handling of renamed alternatives
- added warning message if multibouquet is disabled on your dreambox
- added signal strength indicator
- fixed renumbering channel numbers after using "sort alphabetically" from context menu
- fixed when sorting by frequency now also sorting by polarisation is applied
- fixed problem with missing objects (service counter, profile selection)
- fixed cut&paste services with alternatives
- fixed saving of current profile when options panel is closed
- integrated language tool (Help -> Language Tool)
- removed LanguageTool.exe from installation package
- removed outdated help files
- some minor fixes
The the following features are only supported on genuine Dreamboxes with -Images based on Release 3.2 or higher
- full support for filtering of encrpyted services is now enabled
- full support for streaming services in userbouquets
- added video streaming support
Note: VLC 1.1.11 or higher is required, the installation directory is detected automatically, if you are using
a portable version set the VLC installation directory in the options panel.
- added support for taking snapshots of currently played stream​
  • dreamboxEDIT_setup_5.0.0.0.zip
  • dreamboxEDIT_without_setup_5.0.0.0.zip
tae
dreamboxEDIT_5.0.0.1
5.0.0.1
- fixed compatibility problems when running dreamboxEDIT under wine
Note: skinning support is automatically disabled, Wine 1.3.34 or higher is mandatory
- some language file updates
  • dreamboxEDIT_setup_5.0.0.1.zip
  • dreamboxEDIT_without_setup_5.0.0.1.zip
mr.strauss
DreamboxEdit 5.0.02
5.0.0.2
- fixed streaming for WebInterface 1.7.0 and higher
  • dreamboxEDIT_setup_5.0.0.2.zip
  • dreamboxEDIT_without_setup_5.0.0.2.zip
mr.strauss
dreamboxEDIT 5.0.0.3
5.0.0.3
- changed QuickFTP buttons to avoid further confusions
- fixed hiding QuickFTP buttons if disabled in options
- some minor fixes
Thx dhwz
  • dreamboxEDIT_setup_5.0.0.3.zip
  • dreamboxEDIT_without_setup_5.0.0.3.zip
vocian
dreamboxEDIT 5.0.1.0
5.0.1.0
- added new hints in main list, now with bouquet references
- fixed application closing after canceling
- fixed error message after dropping service on current bouquet
- fixed main service list refresh after selection of another bouquet
  • dreamboxEDIT_setup_5.0.1.0.zip
  • dreamboxEDIT_without_setup_5.0.1.0.zip
