gobi2000
Non richonose queta tipo di usb ?
T: Bus=03 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=08e6 ProdID=3437 Rev= 1.00
S: Manufacturer=Gemplus
S: Product=USB SmartCard Reader
C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=0b(scard) Sub=00 Prot=00 Driver=(none)
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=24ms
root@vuuno:/usr/bin# pcscd -d -f
00000000 pcscdaemon.c:233:main() pcscd set to foreground with debug send to stdout
00000651 configfile.l:298:DBGetReaderList() Parsing conf file: /etc/reader.conf.d
00000163 pcscdaemon.c:518:main() pcsc-lite 1.8.3 daemon ready.
00026407 hotplug_libusb.c:514:HPAddHotPluggable() Adding USB device: 3:2:0
00000377 readerfactory.c:936:RFInitializeReader() Attempting startup of Gemalto PC Twin Reader 00 00 using /usr/lib/pcsc/drivers/ifd-ccid.bundle/Contents/Linux/libccid.
00001896 readerfactory.c:826:RFBindFunctions() Loading IFD Handler 3.0
00000678 ifdhandler.c:1768:init_driver() Driver version: 1.4.6
00008598 ifdhandler.c:1785:init_driver() LogLevel: 0x0003
00000236 ifdhandler.c:1796:init_driver() DriverOptions: 0x0000
00001467 ifdhandler.c:83:CreateChannelByNameOrChannel() Lun: 0, device: usb:08e6/3437:libusb-1.0:3:2:0
00007437 ccid_usb.c:245:OpenUSBByName() ifdManufacturerString: Ludovic Rousseau (ludovic.rousseau@free.fr)
00000249 ccid_usb.c:246:OpenUSBByName() ifdProductString: Generic CCID driver
00000145 ccid_usb.c:247:OpenUSBByName() Copyright: This driver is protected by terms of the GNU Lesser General Public License version 2.1, or (at your option) any later
00011557 ccid_usb.c:509:OpenUSBByName() Found Vendor/Product: 08E6/3437 (Gemalto PC Twin Reader)
00000298 ccid_usb.c:511:OpenUSBByName() Using USB bus/device: 3/2
00003452 ccid_usb.c:1009:get_data_rates() declared: 10753 bps
00000120 ccid_usb.c:1009:get_data_rates() declared: 14337 bps
00000107 ccid_usb.c:1009:get_data_rates() declared: 15625 bps
00000075 ccid_usb.c:1009:get_data_rates() declared: 17204 bps
00000075 ccid_usb.c:1009:get_data_rates() declared: 20833 bps
00000073 ccid_usb.c:1009:get_data_rates() declared: 21505 bps
00000074 ccid_usb.c:1009:get_data_rates() declared: 23438 bps
00000073 ccid_usb.c:1009:get_data_rates() declared: 25806 bps
00000073 ccid_usb.c:1009:get_data_rates() declared: 28674 bps
00000074 ccid_usb.c:1009:get_data_rates() declared: 31250 bps
00000126 ccid_usb.c:1009:get_data_rates() declared: 32258 bps
00000075 ccid_usb.c:1009:get_data_rates() declared: 34409 bps
00000072 ccid_usb.c:1009:get_data_rates() declared: 39063 bps
00000073 ccid_usb.c:1009:get_data_rates() declared: 41667 bps
00000072 ccid_usb.c:1009:get_data_rates() declared: 43011 bps
00000073 ccid_usb.c:1009:get_data_rates() declared: 46875 bps
00000073 ccid_usb.c:1009:get_data_rates() declared: 52083 bps
00000110 ccid_usb.c:1009:get_data_rates() declared: 53763 bps
00000074 ccid_usb.c:1009:get_data_rates() declared: 57348 bps
00000074 ccid_usb.c:1009:get_data_rates() declared: 62500 bps
00000072 ccid_usb.c:1009:get_data_rates() declared: 64516 bps
00000072 ccid_usb.c:1009:get_data_rates() declared: 68817 bps
00000099 ccid_usb.c:1009:get_data_rates() declared: 71685 bps
00000080 ccid_usb.c:1009:get_data_rates() declared: 78125 bps
00000073 ccid_usb.c:1009:get_data_rates() declared: 83333 bps
00000075 ccid_usb.c:1009:get_data_rates() declared: 86022 bps
00000072 ccid_usb.c:1009:get_data_rates() declared: 93750 bps
00000074 ccid_usb.c:1009:get_data_rates() declared: 104167 bps
00000073 ccid_usb.c:1009:get_data_rates() declared: 107527 bps
00000074 ccid_usb.c:1009:get_data_rates() declared: 114695 bps
00000072 ccid_usb.c:1009:get_data_rates() declared: 125000 bps
00000074 ccid_usb.c:1009:get_data_rates() declared: 129032 bps
00000073 ccid_usb.c:1009:get_data_rates() declared: 143369 bps
00000073 ccid_usb.c:1009:get_data_rates() declared: 156250 bps
00000072 ccid_usb.c:1009:get_data_rates() declared: 166667 bps
00000124 ccid_usb.c:1009:get_data_rates() declared: 172043 bps
00000077 ccid_usb.c:1009:get_data_rates() declared: 215054 bps
00000073 ccid_usb.c:1009:get_data_rates() declared: 229391 bps
00000072 ccid_usb.c:1009:get_data_rates() declared: 250000 bps
00000074 ccid_usb.c:1009:get_data_rates() declared: 344086 bps
00111878 commands.c:870:CmdEscape error on byte 10
00000145 ccid.c:205:set_gemalto_firmware_features() GET_FIRMWARE_FEATURES failed: 612, len=0
00000173 ifdhandler.c:353:IFDHGetCapabilities() tag: 0xFB3, usb:08e6/3437:libusb-1.0:3:2:0 (lun: 0)
00000150 readerfactory.c:296:RFAddReader() Using the reader polling thread
00003924 ifdhandler.c:353:IFDHGetCapabilities() tag: 0xFAE, usb:08e6/3437:libusb-1.0:3:2:0 (lun: 0)
00000148 ifdhandler.c:441:IFDHGetCapabilities() Reader supports 1 slot(s)
00000961 readerfactory.c:1303:RFWaitForReaderInit() Waiting init for reader: Gemalto PC Twin Reader 00 00
00000264 hotplug_libusb.c:421:HPEstablishUSBNotifications() Driver ifd-ccid.bundle does not support IFD_GENERATE_HOTPLUG. Using active polling instead.
00000235 hotplug_libusb.c:430:HPEstablishUSBNotifications() Polling forced every 1 second(s)
00005903 ifdhandler.c:1114:IFDHPowerICC() action: PowerUp, usb:08e6/3437:libusb-1.0:3:2:0 (lun: 0)
00003947 readerfactory.c:1303:RFWaitForReaderInit() Waiting init for reader: Gemalto PC Twin Reader 00 00
00010216 readerfactory.c:1303:RFWaitForReaderInit() Waiting init for reader: Gemalto PC Twin Reader 00 00
00010211 readerfactory.c:1303:RFWaitForReaderInit() Waiting init for reader: Gemalto PC Twin Reader 00 00
00010250 readerfactory.c:1303:RFWaitForReaderInit() Waiting init for reader: Gemalto PC Twin Reader 00 00
00010220 readerfactory.c:1303:RFWaitForReaderInit() Waiting init for reader: Gemalto PC Twin Reader 00 00
00003057 eventhandler.c:256:EHStatusHandlerThread() powerState: POWER_STATE_POWERED
00000155 Card ATR: XX XX XX XX XX XX XX XX ..... 03
05007737 ifdhandler.c:1114:IFDHPowerICC() action: PowerDown, usb:08e6/3437:libusb-1.0:3:2:0 (lun: 0)
00003991 eventhandler.c:446:EHStatusHandlerThread() powerState: POWER_STATE_UNPOWERED
^C06947068 pcscdaemon.c:680:signal_trap() Received signal: 2
00000078 pcscdaemon.c:699:signal_trap() Preparing for suicide
00102983 hotplug_libusb.c:383:HPRescanUsbBus() Hotplug stopped
00897200 readerfactory.c:1256:RFCleanupReaders() entering cleaning function
00000101 readerfactory.c:1265:RFCleanupReaders() Stopping reader: Gemalto PC Twin Reader 00 00
00000059 eventhandler.c:148:EHDestroyEventHandler() Stomping thread.
00000060 ifdhandler.c:353:IFDHGetCapabilities() tag: 0xFB1, usb:08e6/3437:libusb-1.0:3:2:0 (lun: 0)
00000060 ifdhandler.c:353:IFDHGetCapabilities() tag: 0xFB2, usb:08e6/3437:libusb-1.0:3:2:0 (lun: 0)
00000055 eventhandler.c:173:EHDestroyEventHandler() Request stoping of polling thread
00000052 ifdhandler.c:318:IFDHStopPolling() usb:08e6/3437:libusb-1.0:3:2:0 (lun: 0)
00400659 eventhandler.c:469:EHStatusHandlerThread() Die
00000385 eventhandler.c:188:EHDestroyEventHandler() Thread stomped.
00000066 readerfactory.c:987:RFUnInitializeReader() Attempting shutdown of Gemalto PC Twin Reader 00 00.
00000151 ifdhandler.c:244:IFDHCloseChannel() usb:08e6/3437:libusb-1.0:3:2:0 (lun: 0)
00004189 readerfactory.c:863:RFUnloadReader() Unloading reader driver.
00002045 winscard_svc.c:130:ContextsDeinitialize() remaining threads: 0
00000090 pcscdaemon.c:629:at_exit() cleaning /var/run/pcscd
