Drivers for Sundtek Media TV Pro
How can I understand - on which side the promlem I have ?
Options are
- incomplete CI+ module initialization (as affect, the Enigma passed to stick only formal PMT, EIT, APID, VPID, but not CA- and OTA- PIDS) ?
- the TS stream, which injected from USB-tuner to the Enigma is not reach the CAM-bus ?
Options are
So, your cable provider uses CI+ cams/pairing?
it is no go with VU+. Enigma2 boxes do not support CI+, if cable provider use all its features.
It´s also no go with softcams, if provider use somekind of Conax pairing or CI+.
Yes
Why it works on DM 7025 boxes with builtin DVB-C tuners ? It also E2 box..
And finally, my provider is not declare the usage of an CI+ options. It just declare potential misses on the future possibilities, if customer at current moment have the equipment with the CI interface only (without "+" sign)
So, the question is - why it "no go" with the VU+ units.
This is the HardWare limitation or SoftWare?
Should I wait for the fix the driver from Marusys, or I must sell my STB?
