komodo
Hi,
i want to add this to Black Hole how to, but i don't have rights to do this, so i put it here.
I use ssh for accessing my VU+ Solo2, and if you access machine from the internet, it's bad idea to allow password auth.
So here is how to disable password auth and allow only public key auth.
It's for linux users, if you use windows you can use Putty.
First make your own public key
on your desktop run
ssh-keygen -t dsa
there you may put the password for your key, but it's not required.
Then copy content of /yourhome/.ssh/id_dsa.pub to VU+ /root/.ssh/authorized_keys
From now you should be able to login without password.
And now disable password auth in dropbear.
Create file
/etc/default/dropbear
and put in it
DROPBEAR_EXTRA_ARGS="-s -g"
restart dropbear and that's all.
Now you may login only with accepted public key.
Regards
Martin
on your desktop run
ssh-keygen -t dsa
Create file
and put in it
Regards
Martin
