sorry...but were can i found dts plugin for blach hole 1.7.8 ...i have avatar movie and cannot use dts sound over optical. thank you!
Can I just make a little question?
About DTS, this works by HDMI cable too? I mean, the RAW works by HDMI cable to my Home Cinema too or I always need an Optical cable?
Thanks and sorry the lame question!
What I meant was if Vu+ can pass RAW sound to HC by HDMI, and then HC "decode" the sound properly or that is only possible by optical cable??
Thanks!![]()
Thanks a lot to both!
That's what I'm really looking for!
I cant wait for a Solo2 machine
Thanks once again my dear friends @baw and @angelofsky1980
Regards
i use the optical and hdmi and both work perfectly with dts!![]()
