DonaldDuck
While watching terrestrial tv I had a freeze, tried to restart but I have no DTT channels and no DTT tuner. Where is the DTT tuner menu? I can't find it...
tnx
DD
tnx
DD
menu,configuration,scan channels,tuner configuration........While watching terrestrial tv I had a freeze, tried to restart but I have no DTT channels and no DTT tuner. Where is the DTT tuner menu? I can't find it...
tnx
DD
should be usb tuner panel...which BH do you have?uhm... I press blue, blue then?
so you have a usb stick for dtt right?1.7.2 on vu+duo
i ask you which Bh do you have, 'cause since 1.70 or 1.71(i think) this menu (usb tuner panel) doesn't exist anymore..(all usb stick drivers are inside the image..)and btw it is working now. I pulled out my nova tv and popped in an aver 867
It works, but I can't see a dtt tuner panel
