DUO2 Failed to start
I've used my WiFi option all night, including Kodi, without any problems, on my Duo2.
Either the problem is your receiver, your router, possibly the distance is too great, interference, or you haven't set it up correctly.
All I am able to report is that my internal Duo2 WiFi connection works, without any drop outs.
Ok then it's my installation. However it seems now I've got the LAN connection I can manage without the WiFi.
Thanks again for all the help. I'm happy with the upgrade and now have installed the latest version.
Cheers
