DvbS2 Technisat Skystar Usb HD
Burley
This unit i get not to work,but no frontend (stv6110x)will be attached.
Manually modprobe doesn t bring any effect on it.
root@vusolo2:~# lsmod
Module Size Used by Tainted: P
dvb_usb_technisat_usb2 8982 0
stv090x 60840 1 dvb_usb_technisat_usb2
dvb_usb 22410 1 dvb_usb_technisat_usb2
bh_dvb_core 87658 2 dvb_usb_technisat_usb2,dvb_usb
bh_rc_core 14669 3 dvb_usb_technisat_usb2,dvb_usb
ipv6 311826 12
uas 7754 0
fpga_directc 57649 0
brcmfb 1238 3
dvb_bcm7356 11704403 2 fpga_directc,brcmfb
procmk 1445 2 fpga_directc,dvb_bcm7356
root@vusolo2:~# dmesg | grep DVB
DVB: registering new adapter (vusolo2)
DVB: registering adapter 0 frontend 0 (BCM7346 FE)...
dvb-usb: found a 'Technisat SkyStar USB HD (DVB-S/S2)' in cold state, will try to load a firmware
dvb-usb: generic DVB-USB module successfully deinitialized and disconnected.
dvb-usb: found a 'Technisat SkyStar USB HD (DVB-S/S2)' in warm state.
DVB: registering new adapter (Technisat SkyStar USB HD (DVB-S/S2))
dvb-usb: no frontend was attached by 'Technisat SkyStar USB HD (DVB-S/S2)'
input: IR-receiver inside an USB DVB receiver as /devices/platform/ehci-brcm.3/usb4/4-1/bh-rc/rc0/input1
rc0: IR-receiver inside an USB DVB receiver as /devices/platform/ehci-brcm.3/usb4/4-1/bh-rc/rc0
dvb-usb: Technisat SkyStar USB HD (DVB-S/S2) successfully initialized and connected.
dmesg
usbcore: registered new interface driver dvb_usb_technisat_usb2
usb 4-1: USB disconnect, device number 2
usb 4-1: new high-speed USB device number 3 using ehci-brcm
technisat-usb2: set alternate setting
technisat-usb2: firmware version: 17.63
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
dvb-usb: MAC address: xxxx
technisat-usb2: i2c-error: 68 = 64
IR keymap rc-technisat-usb2 not found
Registered IR keymap rc-empty
dvb-usb: schedule remote query interval to 100 msecs.
Can anybody see,what the problem here is?....VU Kernel?Because other
Team images have the same problem with "no frontend".
angelofsky1980
BlackHole Driver Specialist
I need the complete dmesg after a box reboot with DVB USB device connected.
The partial dmesg posted is not clear where is the problem.
Thanks
Burley
Ok,here is complette dmesg,from Box after a reboot...
Linux version 3.3.6-1.2 (amedeo@localhost.localdomain) (gcc version 4.6.4 20120303 (prerelease) (GCC) )
#1 SMP Tue Feb 19 14:27:14 CET 2013
Fetching vars from bootloader... found 15 vars.
Options: moca=0 sata=1 pcie=0 usb=1
Using 1024 MB + 0 MB RAM (from CFE)
bootconsole [early0] enabled
CPU revision is: 00025a11 (Brcm4380)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
memory: 30000000 @ 20000000 (usable)
bmem: adding 57 MB LINUX region at 6 MB (0x03924000@0x006dc000)
bmem: adding 192 MB RESERVED region at 64 MB (0x0c000000@0x04000000)
bmem: adding 256 MB RESERVED region at 512 MB (0x10000000@0x20000000)
bmem: adding 512 MB LINUX region at 768 MB (0x20000000@0x30000000)
Zone PFN ranges:
  Normal  0x00000000 -> 0x00050000
Movable zone start PFN for each node
Early memory PFN ranges
    0: 0x00000000 -> 0x00010000
    0: 0x00020000 -> 0x00050000
On node 0 totalpages: 262144
free_area_init_node: node 0, pgdat 8068e680, node_mem_map 81000000
  Normal zone: 2560 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 259584 pages, LIFO batch:31
PERCPU: Embedded 7 pages/cpu @81a09000 s5632 r8192 d14848 u32768
pcpu-alloc: s5632 r8192 d14848 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 259584
Kernel command line: ubiroot rootflags=sync bmem=192M@64M bmem=256M@512M ubi.mtd=rootfs rootfstype=ubifs
root=ubi0:rootfs
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Primary instruction cache 32kB, physically tagged, 4-way, linesize 64 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
MIPS secondary cache 256kB, 8-way, linesize 128 bytes.
Memory: 571672k/1048576k available (5585k kernel code, 476904k reserved, 1130k data, 184k init, 0k highmem)
Hierarchical RCU implementation.
NR_IRQS:160
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 1305 MHz (163.136 MHz counter)
Calibrating delay loop... 869.37 BogoMIPS (lpj=434688)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
bcm40nm_pm_moca_disable 00
SMP: Booting CPU1...
SMP: CPU1 is running
Brought up 2 CPUs
devtmpfs: initialized
NET: Registered protocol family 16
USB0: power enable is active high; overcurrent is active low
USB1: power enable is active high; overcurrent is active low
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource wktmr
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Registering unionfs 2.5.11 (for 3.3.0-rc3)
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NTFS driver 2.1.30 [Flags: R/W].
msgmni has been set to 1116
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10406900 (irq = 65) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10406940 (irq = 66) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10406980 (irq = 67) is a 16550A
loop: module loaded
__clk_enable: sata [1]
bcm40nm_pm_sata_enable 00
ahci: SSS flag set, parallel bus scan disabled
ahci strict-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci strict-ahci.0: flags: ncq sntf stag clo slum part
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x100 irq 41
ata2: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x180 irq 41
brcmstb_nand: NAND controller driver is loaded
__clk_enable: network [1]
__clk_enable: enet [1]
bcm40nm_pm_genet_enable 00
Found PHY at Address 3
Config GPHY through MDIO
__clk_disable: enet [0]
bcm40nm_pm_genet_disable 00
__clk_disable: network [0]
__clk_enable: moca_genet [1]
bcm40nm_pm_genet1_enable 00
__clk_enable: moca [1]
bcm40nm_pm_moca_enable 00
ata1: SATA link down (SStatus 0 SControl 300)
No PHY detected, not registering interface:1
ata2: SATA link down (SStatus 0 SControl 300)
__clk_disable: moca [0]
__clk_disable: moca_genet [0]
bcm40nm_pm_genet1_disable 00
bcmgenet: probe of bcmgenet.1 failed with error -5
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
__clk_enable: usb [1]
bcm40nm_pm_usb_enable 00
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 69, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 70, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ehci-brcm ehci-brcm.2: Broadcom STB EHCI
ehci-brcm ehci-brcm.2: new USB bus registered, assigned bus number 3
ehci-brcm ehci-brcm.2: irq 74, io mem 0x10490300
ehci-brcm ehci-brcm.2: USB 0.0 started, EHCI 1.00
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ehci-brcm ehci-brcm.3: Broadcom STB EHCI
ehci-brcm ehci-brcm.3: new USB bus registered, assigned bus number 4
ehci-brcm ehci-brcm.3: irq 75, io mem 0x10490500
ehci-brcm ehci-brcm.3: USB 0.0 started, EHCI 1.00
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 5
ohci-brcm ohci-brcm.0: irq 71, io mem 0x10480400
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 6
ohci-brcm ohci-brcm.1: irq 72, io mem 0x10480600
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 1 port detected
ohci-brcm ohci-brcm.2: Broadcom STB OHCI
ohci-brcm ohci-brcm.2: new USB bus registered, assigned bus number 7
usb 2-1: new high-speed USB device number 2 using ehci-brcm
ohci-brcm ohci-brcm.2: irq 76, io mem 0x10490400
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 1 port detected
ohci-brcm ohci-brcm.3: Broadcom STB OHCI
ohci-brcm ohci-brcm.3: new USB bus registered, assigned bus number 8
ohci-brcm ohci-brcm.3: irq 77, io mem 0x10490600
hub 8-0:1.0: USB hub found
hub 8-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
scsi2 : usb-storage 2-1:1.0
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device  success with 0
blackhole initialised
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
  No soundcards found.
TCP cubic registered
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
usb 4-1: new high-speed USB device number 2 using ehci-brcm
EBI CS0: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
nand_read_bbt: bad block at 0x000008220000
nand_read_bbt: bad block at 0x00000a5e0000
nand_read_bbt: bad block at 0x00000aba0000
nand_read_bbt: bad block at 0x00000ce60000
nand_read_bbt: bad block at 0x00000f060000
Creating 4 MTD partitions on "brcmnand.0":
0x000001f00000-0x000010000000 : "rootfs"
0x000001f00000-0x000010000000 : "rootfs(redundant)"
0x000000200000-0x000000900000 : "kernel"
0x000000900000-0x000000a00000 : "mac"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size:  131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
scsi 2:0:0:0: Direct-Access                              8.07 PQ: 0 ANSI: 2
sd 2:0:0:0: Attached scsi generic sg0 type 0
sd 2:0:0:0: [sda] 15155200 512-byte logical blocks: (7.75 GB/7.22 GiB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Mode Sense: 03 00 00 00
sd 2:0:0:0: [sda] No Caching mode page present
sd 2:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 2:0:0:0: [sda] Attached SCSI removable disk
UBI: max. sequence number:      531
UBI: attached mtd0 to ubi0
UBI: MTD device name:            "rootfs"
UBI: MTD device size:            225 MiB
UBI: number of good PEBs:        1791
UBI: number of bad PEBs:        9
UBI: number of corrupted PEBs:  0
UBI: max. allowed volumes:      128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:    1
UBI: available PEBs:            0
UBI: total number of reserved PEBs: 1791
UBI: number of PEBs reserved for bad PEB handling: 17
UBI: max/mean erase counter: 3/1
UBI: image sequence number:  873754782
UBI: background thread "ubi_bgt0d" started, PID 47
UBIFS: parse sync
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size:  223350784 bytes (218116 KiB, 213 MiB, 1759 LEBs)
UBIFS: journal size:      9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format:      w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root:  0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:14.
devtmpfs: mounted
Freeing unused kernel memory: 184k freed
rtw driver version=v3.4.4_xxxx.20120730
Build at: Feb 19 2013 15:02:55
usbcore: registered new interface driver rtl8192cu
NET: Registered protocol family 10
procmk_init
dvb_bcm7356: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
bcm7335: hotplug_callback():
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0xe
[GP]:brcm_pwm_init
brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
[MPVR]: >> misc_pvr_init
BKNI_P_GetTrackAllocEntry_resize: resizing from 4096->8192
BKNI_Malloc(linuxkernel) top users:
    blocks,  bytes, filename:line
      694,  33312, magnum/portinginterface/vdc/7346/bvdc_bufferheap_priv.c:737
      562,  127496, ../BSEAV/lib/utils/balloc.c:35
      536,  21440, ../magnum/basemodules/mem/bmem_system.c:286
      366,  43920, magnum/commonutils/mrc/7346/bmrc_monitor.c:940
input: dreambox advanced remote control (native) as /devices/virtual/input/input0
[LCD]: registered
[CI]: registered ci0
[DFP]: registered dbox fp
[DFP]: Scart 9597 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
fpga update driver loaded
udevd (116): /proc/116/oom_adj is deprecated, please use /proc/116/oom_score_adj instead.
usbcore: registered new interface driver uas
WARNING: You are using an experimental version of the media stack.
        As the driver is backported to an older kernel, it doesn't offer
        enough quality for its usage in production.
        Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
        Custom Black Hole build
        Use it with care.
ADDRCONF(NETDEV_UP): eth0: link is not ready
eth0: Link up, 100 Mbps Full Duplex
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
svc: failed to register lockdv1 RPC service (errno 124).
[LCD]: unknown cmd 0x1015
[CI]: CI interface initialised
eth0: no IPv6 routers present
FE tune
root@vusolo2:~#
angelofsky1980
Zone PFN ranges:
root=ubi0:rootfs
NR_IRQS:160
Brought up 2 CPUs
TCP reno registered
loop: module loaded
ALSA device list:
sda: sda1
UBIFS: parse sync
devtmpfs: mounted
procmk_init
[GP]:brcm_pwm_init
[LCD]: registered
        Use it with care.
        Use it with care.
FE tune
root@vusolo2:~#
Semms that your box doesen't load correctly the modules....
The missing module should be the stv6110x.ko .... the module is present into the box (checked the Uno image version) ...
Could you please psot the output of the command
lsmod
Burley
See in the first post there for lsmod log...
I have seen that stv6110x is not loaded and so i "modprobe stv6110x" and after that, it
loads the module manually ,but it still will be not recognized.
angelofsky1980
I will look into drivers sources about STV6110x modules
Burley
Now added 6110x to file "modules.dep",but after reboot box will not start.
Have to reflash image.
Any more things to test for me in this issue?
Burley
Tested new image ,but nothing changed!
See .txt for more!
  • putty.txt
angelofsky1980
angelofsky1980
I've a question for you: there are some revision numbers reported on your device?
Any kind of infos can be useful to discover the problem.
Seems that your device is different than the one already supported by BH images.
I've reviewed the driver sources but seems all OK.
Burley
the inside pcb is signed and there is also a sticker.
Don t want to open it,but what i can see,is:
Sticker:
"Skystar PC05 USB S2 64683"
Pcb:
"Skystar....bla,bla.....
6414-500-v4 SCH-v6"
New Revisions?
With (some times older)actuell Pc win driver box is working.
Burley
Only one time i got Solo2 to recognize skystar "nearly" full.
It was a Vu+ Org Image1.6 from march.
When i installed fresh image,skystar were shown in Assistant
GUI as 3, Tuner,but no successful channelsearch possible....
Dmesg showed only different I2C errors.
After newstart box were not recognized anymore in this way
and since this time want the replay situation,but no success.
angelofsky1980
New Revisions?
It's the only thing that I can suppose because into drivers sources all things are correct and the STV6110x module is correctly selected as dependency.
Windows and Linux drivers are DIFFERENT things and cannot be compared.
Thanks for your post.
Your device has CI slot?
Burley
Have no CI modell,thats complete different hardware.
Look like i have same pcb revision,as here (Linux Tv)
When all drivers are ok,what is the issue?
..and why the hell ,vu+ org 1.6 image have recognized it one time?
I`m not joking,but only have some photos of the GUI.
I m confused now.
crazycat
look like errors in I2C-access code.
Increase debug level for dvb_usb_technisat-usb2 module.
Create /etc/modprobe.d/technisat-usb2.conf with
options dvb_usb_technisat-usb2 debug=7
Burley
Ok,i understand,see putty.log for dmesg and lsmod,the only other thing
i see is:
"dvb-usb: error -71 while querying for an remote control event."
But haven t touched the RC.
Correct MAC Adress is shown in log,but i have censored it .
  • putty.txt
