dvd+rw-mediainfo
Seth
can any one tell me where i can get dvd+rw-mediainfo its for burndvd plugin i cant get burndvd program to find dvd media disc
Persian Prince
to display information about dvd drive and disk you can use dvd+rw-mediainfo command :
# dvd+rw-mediainfo /dev/dvd
it's not for dvd burn plugin
if you wanna work with dvd burn plugin you should install these files :
bzip2_1.0.5-r2_mipsel.ipk
cdrkit_1.1.9-r3_mipsel.ipk
dvd+rw-tools_7.1-r2_mipsel.ipk
dvdauthor_0.6.14-r2_mipsel.ipk
libattr_2.4.43-r0_mipsel.ipk
libbz2-1_1.0.5-r2_mipsel.ipk
libcap2_2.16-r1_mipsel.ipk
mjpegtools_1.9.0rc3-r0_mipsel.ipk
projectx_0.90.4.00.b32-r0_mipsel.ipk
python-imaging_1.1.6-ml1_mipsel.ipk
you can find them on Persian HD Project online server
good luck
Seth
good luck
hello and thanks for the files but one question , it wont start burning , its finds everything my dvdrw and dvd+r disc but burning failure
it like it wont start burning , do you got any idea.
thanks
Persian Prince
actually you should only use dvd burn plugin with original enigma2 default skin (you can find it in dm8000 latest enigma2 files) , as i know dvd burn plugin just works with that
good luck
Seth
good luck
thanks for the help but i wounder exact whitch skin i need to download
kind regards
Seth
thanks for the help but i have no luck at all my burner wont start burn i can make dvd and all the other things but it will always be burner failure it doesent start so i give up now but thanks
rurs
Hi, followed instructions in this thread, have successfully burned one DVD-R with LG GE20LU10.
However, when I try to play it in DVD player, I get picture, but no sound. (Audio is MPEG2, says it is running)
I can play the video ts folder in media player, video and audio, but why won't it work with DVD player?
